Woodturning
Canadian Woodworking woodturning articles explore lathe projects, hand-tool techniques, sharpening tips, wood selection, and creative approaches for shaping expressive, finely detailed wooden forms.
  • Turning a tulip
    With a few offcuts, a few dollar store dowels, a little colour and some glue you can make a beautiful bouquet of tulips to give to that special someone, and they’ll last forever.
    November 14, 2022
    Allan Cusworth
  • Lidded chalice
    Turn a lidded chalice
    A lidded chalice is an interesting switch in the production of vessels on a woodturning lathe. It expands the process of hollowing, as well as lid fitting. It also allows a box to be made with a decorative finial.
    March 7, 2022
    Allan Cusworth
  • Pencil Crayon Pen
    Turn a pencil crayon pen
    You may have seen these turned pens made from pencil crayons before, but you’ve probably never seen one that’s so easy to make. Forget about resins, casting and pressure pots. All you need here is plenty of CA glue.
    January 13, 2021
    James Dobson
  • Carve a curvy spoon
    Great for measuring ground coffee or mixing up a few ingredients, this spoon has enough curves to also catch everyone’s eye.
    August 13, 2020
  • Löfftel
    Make a LÖFFTEL
    A Löfftel is a spatula / spoon hybrid that’s sort of the multi-tool of cooking. Make one today and you’ll forever wonder what you did without it.
    August 13, 2020
    Wilfried Elzner
  • Sunrise Bowl
    Turn a sunrise bowl
    Adding some contrasting, figured wood to a piece is sometimes all that's needed in order to make it stand out from the crowd.
    September 13, 2019
    Ken Rude
  • turned wave platter
    Build a Turned Wave Platter
    Use your lathe to turn an offset platter with wave-like undulations on its surface. It’s easier than you’d think.
    March 10, 2019
    Lisa Chemerika
  • Open-Backed Clock
    Turn an Open-Backed Clock
    This fun and functional project can be made by any novice wood turner.
    February 13, 2019
    Douglas Gillie
  • Hollow Vessel
    Turn a four-sided hollow vessel
    If you want to take your hollow turning to the next level to create something unique this approach will intrigue you. And don't stop here – try your hand at creating an eight-sided vessel, or possibly cut the turning across the grain, rather than with the grain.
    September 13, 2018
    Trent Watts
  • Salad Bowl
    Turn a Salad Bowl with a Textured Band
    A large salad bowl is one of the most sought after woodturning bowl designs. Here’s how to turn one that you can be proud of.
    January 13, 2018
    Allan Cusworth
  • Ruffled Bowl
    Ruffled Bowl
    If a stunning centerpiece, or a unique gift, is what you’re after, look no further. This turned and shaped piece of wood art is a lot of fun to build, and can be modified in many different ways to suit your taste.
    July 13, 2017
    Lisa Chemerika
  • Eccentric Pedestal Bowl
    Turn an Eccentric Pedestal Bowl
    Follow the steps properly and you will open your eyes to the wonderful world of eccentric turning. Once you finish this piece, and have a good command of the process, you’ll be able to design all sorts of interesting and unique eccentric turnings.
    November 13, 2016
    Allan Cusworth
  • Spin Tops
    Turn some spin tops
    Turning spin tops is easy, highly productive and lots of fun. And if you’re into craft shows, they’re good sellers.
    November 13, 2015
    Art Betke
  • turned boxes
    Making Turned Boxes
    The great thing about box making is that it can be a good way of using up a small piece of wood, even an offcut, that might otherwise end up being discarded. It can be transformed into a thing of beauty, using your imagination, originality and skill.
    September 13, 2014
    Stevcen Kennard
Next
