Get the most out of your jointer (webinar video)
In this webinar recording, David Bedrosian covers the essentials of using a jointer, from setup to real-world milling techniques.
Canadian Woodworking offers detailed product profiles and hands‑on reviews of jointers and planers, helping you choose machines that deliver flat, square, and consistent stock.
The compact design and powerful motor combined with the carbide cutters make this a great planer for the small shop.
Flat and straight, with ease
The Laguna PX12 has some great features and would be a great addition to any small shop. It has lots of power and produces a smooth finish quickly on any wood.
King Canada 6″ benchtop jointer with helical cutterhead
A great combination of performance, precision, portability and price.
Also called lunchbox planers, a benchtop thickness planer is a cost effective way to machine lumber to final thickness.
Get the Most Out Of Your Jointer. Jointers are available in benchtop or stationary format.
Introduction to helical cutter heads
There are many advantages to using a helical cutter head in your planer or jointer, but they aren’t cheap. Is a helical cutter head something you should consider? Learn what the buzz is all about.
Bells and whistles often make it hard to see what tool will perform the basic tasks being asked of it. Sort through what is and what isn’t important when buying a bench-top planer.
Most of us have limited space in our shops, so which jointer should you choose to take up valuable real estate?
Once you decide to try your hand at some finer woodworking, you soon realize the need for a jointer and thickness planer.
Owning a jointer and thickness planer frees you from buying pre-milled lumber with fixed dimensions. You might want to build a project with ⅞" thick stock when only ¾" is readily available.
The 6" jointer is a shop staple. Without it, truing rough lumber would be a burdensome chore.
