Home » Design Details
Design Details
Design Details, from Canadian Woodworking, shares practical design insights and techniques to help you create stronger, more thoughtful woodworking projects.
  • Machining metal rods
    In this video Robert Brown shows how he machined the threaded rods in his "Makeup Organizer" article in the Spring 2024 issue.
    February 18, 2024
  • Faux tenons
    Faux tenons
    Sometimes introducing a decorative element to a joint is all that’s needed to add beauty to a project. Learn how to make a joint look even more attractive with these simple steps.
    July 23, 2023
  • Curvy doors
    Design and build curvy doors
    Doors are a blank canvas, just waiting to be sculpted, carved, shaped or curved. The technique described here can be used on just about any door, so let your creativity run wild.
    January 15, 2023
  • Referent based design
    Referent-based design
    How is it that we learn to create? Is it possible to learn creativity? Is there a skill set from which aspiring artists and designers can extract the tools needed to realize their vision?
    March 23, 2019
    Ken Guenter
  • lounge chair
    Designing and Building the Lounge Chair No. 3
    Through passion, determination and preparation, Nova Scotia designer / maker Jonathan Otter built this award-winning lounge chair. Learn about the process he went through to complete this piece.
    September 13, 2018
    Jonathan Otter
  • lute of illusions
    Lute of illusions
    The original Bosch Lute was made in the 1500s. There is only one of them in the world, but a skilled luthier from Saskatoon completed a very similar lute. Learn how he assembled all the pieces that make up the back of his version of the Bosch Lute.
    March 11, 2016
    Weldon Gray
  • Kids pallet chair
    In this video Rob Brown talks about how he designed and built this chair with the material from one pallet found at a local lumberyard.
    February 16, 2016
  • maple leaf doors
    Carved maple leaf doors
    Removing some material to create textured maple leaves on solid wood door faces will add a simple, natural focal point to any piece of furniture.
    January 30, 2016
  • louis cube design
    Making a Louis Cube Design
    This type of design is quite easy to create, as long as you have the proper jigs and can work fairly accurately.
    November 13, 2015
    Jeremy Pringle
  • Sculpted Joinery
    Sculpted Joinery
    Take advantage of the sculptural properties of wood with this skillfully and tastefully crafted joint.
    September 14, 2015
    Jonathan Otter
  • maple key seed pod box
    Maple Key Seed Pod Box
    The fundamental design of this box is quite simple: a solid base, with routed cavities, topped off with a pair of one-piece lids. There are many options for this basic design. Learn these simple steps, then put your imagination to work, creating a unique design.
    January 20, 2015
  • optical illusions in wood
    Optical illusions in wood
    The only gift more fascinating than a custom-made cutting board is one that incorporates an optical illusion.
    November 21, 2014
    Lisa Chemerika
  • coopered doors
    Coopered doors
    A coopered door is simply one that is curved: concave, convex or, when you combine the two, serpentine. Adding a coopered door can make an amazing difference to a common square cabinet.
    July 24, 2014
    JASON KLAGER
Next
