Tips/Techniques
>Faux tenons
Faux tenons
Sometimes introducing a decorative element to a joint is all... Read more
>How to work wood even if you have no shop
Just because you don’t have a detached garage or part... Read more
>Gluing strategy tips
Glue-ups don’t have to be nerve-wracking experiences. Some basic material... Read more
>Building outdoor woodworking to resist rot
While many of the tools, techniques and materials used to... Read more
>Design and build curvy doors
Doors are a blank canvas, just waiting to be sculpted,... Read more
>Advanced-level chair repair
If you have moderate woodworking skills, you have the necessary... Read more
>Intermediate-level chair repair
If a chair is coming loose, the repair is usually... Read more
>Bird’s mouth lap joint: the simple approach isn’t always the best
There are times when a simple, strong joint is the... Read more
>Two-part epoxies
Two-part epoxies
When you need an adhesive with exceptional shear and peel... Read more
>How to repair a chair
The most common piece of furniture needing repair is the... Read more
>How much solid wood should you buy?
It’s one thing to understand a materials list and project... Read more
>3 simple (yet essential) shop-made router jigs
Routers can be made even more efficient and accurate with... Read more
>Introduction to Brushless Motors
Over the past few years just about every new cordless... Read more
>Strong Curved Panels
Use this technique, combining a coopered solid wood and store-bought... Read more
>3D printers in the workshop
What are 3D printers and do they have a place... Read more
>Shut offs
Shut offs
This article shows you how to fix shut off gates... Read more
>Turn your router into a jointer
Even if you currently have a jointer, there are some... Read more
>The power of wedges
The power of wedges
The simple yet powerful wedge has been around for more... Read more
>Lasers in the workshop
Lasers have helped woodworkers and DIYers for years, but now... Read more
>Simple Router Improvements
The router is a versatile tool. It’s essentially a motor... Read more
>Why You Need an Impact Driver
There’s no doubt that the impact driver is one of... Read more
>Construction adhesives
For construction and renovation work, construction adhesives are what hold... Read more
>7 considerations when buying a reciprocating saw
Don’t hesitate, reciprocate! Take this crash course on reciprocating saws... Read more
>The jointer
The jointer
Get practical tips on how to use the jointer safely... Read more
>Hammer Small Shop Tips
Contest Entries: A special thanks to Hammer for sponsoring Canadian Woodworking... Read more
>12 ways to add texture with tools you already have
If you can open your eyes to what else your... Read more
>Metal Hand Plane Tune Up
Sometimes an inexpensive plane can be transformed into a useful... Read more
>Kolrosing a Wooden Spoon with a Classic Basket Weave
Kolrosing is a wood decorating technique from the Viking age... Read more
>Introduction to Plywood
Understand your plywood options before starting on your next furniture,... Read more
>Saving For Special Projects Scraps
Rather than consigning them to the garbage, or using them... Read more
>Building furniture from scraps
>Buying and Restoring Used Machines – Part 2
In our last issue we covered some tips on how... Read more
>Buying and Restoring Used Machines – part 1
Here are some tips from someone who repairs machinery professionally... Read more
>7 steps to organizing your small shop
Just because your shop space is limited doesn't mean you... Read more
>Sizing down sheet goods with a shop-made saw guide
Cutting sheet goods to size can be a daunting task.... Read more
>French marquetry techniques
Marquetry has been adorning and ornamenting some of the most... Read more
>Learn to work with live-edge wood
Live-edge material is as unique as the tree from which... Read more
>Metalworking for Woodworkers
A little knowledge and experimentation with metal can reward a... Read more
>13 Simple Ways to Improve Accuracy
It sure is nice when you learn a simple, easy... Read more
>Shop and Jobsite LED Lighting
To do good work you need good lighting. We look... Read more
>23 Tips on How to Design, Build and Maintain Your Dock
Docks are the focal point of many cottages, cabins and... Read more
>9 super-simple small shop hacks
Every woodworker would agree that small shop hacks can make... Read more
>Upcycling: How and Why You Should Start Looking for Century-Old Lumber
There are many buildings in Canada that were built in... Read more
>9 TIPS for Using Pallets to Make Furniture
It’s easy to create beautiful, functional pieces of furniture using... Read more
>Installing Straight Knife Hinges
Most other hinges are easier to install, though no other... Read more
>Making a Louis Cube Design
This type of design is quite easy to create, as... Read more
>Sculpted Joinery
Sculpted Joinery
Take advantage of the sculptural properties of wood with this... Read more
>Shaping a Plane Handle
The most enjoyable aspect of plane-making is the woodworking –... Read more
>Iron-On Veneering
Iron-On Veneering
Learning how to apply veneers with an iron can open... Read more
>The Perfect Sphere: A Well-Rounded Tool
Turning spheres free-hand is not easy. This jig makes the... Read more
>Maple Key Seed Pod Box
The fundamental design of this box is quite simple: a... Read more
>Production for Box Making
Making one box is much different than making 100 boxes.... Read more
>Inset pierced carving
Adding small, intricate details, like this Japanese wave motif insert,... Read more
>Curved stretchers
Curved stretchers
This set of three side tables, with delicate curved stretchers,... Read more
>Create negative space
Negative space is a design element that is fairly simple... Read more
>Meteor Cabinet
Meteor Cabinet
The contrasting colour of the stones and the carved texture... Read more
>Making Raised and Stacked Inlays
Inlays are often installed flush to a surface, but this... Read more
>Working with sheet goods in a small shop
Sheet goods are great for many applications in the furniture... Read more
>Flattening a Bench Top
A surface that’s out of flat will do nothing but... Read more
>Give your clamp collection a home
None of us have enough of them, and they all... Read more
>Mastering Grain Graphics
The beauty of working with the wood’s grain lies in... Read more
>Add a Curved Face on a Tapered Leg
We can all make square legs, but what about multiple... Read more
>Wooden Locking Mechanism
If you are looking to spice up your next project,... Read more
>Adding texture to wood
Adding texture to a wood surface creates visual and physical... Read more
>Wave Cabinet
Wave Cabinet
A random wave pattern in wood is fairly easy to... Read more
>Working without numbers
Working without numbers is all about minimizing the risk of... Read more
>A unique way to wrap presents
While you’re wrapping presents this year, head to the shop.... Read more
>Mitred-Through Dovetails
A twist on the original, mitred-through dovetails allow you to... Read more
>Drawer slides: bring on the heavy metal
Learn about the four most popular types of metal slides,... Read more
>Introduce Your Kids to Woodworking
Whether it turns into a hobby or a career (or... Read more
>A New Tool for your Toolbox – The Internet
If you’re not familiar with what is available, woodworking wise,... Read more
>Circular wood handles: beautiful and functional
Instead of installing store-bought handles to doors and drawers, you... Read more
>Top-Notch Drawer
Top-Notch Drawer
Figured wood would have looked great, but this technique adds... Read more
>An Introduction to Stringing and Banding – Part 2
Here’s how to add a high-end accent to your furniture... Read more
>An Introduction to Stringing and Banding – Part 1
>Just Plane Romance
Just Plane Romance
In the age of electric machinery, some woodworkers have forgot... Read more
>Surface Preparation – Hand Planing
Surface preparation is about perfecting your hand skills. Three wonderful... Read more
>Hand-saw Showdown – East vs West: Japanese Style Hand-Saws
With a number of differences between Western and Japanese saws,... Read more
>Hand-saw Showdown – East vs West: Western Style Hand-Saws
>Give your work the edge it deserves
Edge treatments help frame a table or cabinet’s top and... Read more
>Small Shop Storage Solutions
One of the most important aspects of organizing a shop... Read more
>Building big things in a small space
Just because you have a small space to create doesn’t... Read more
>Elegant and practical zebrawood vanity
Bigger isn’t always better. In fact, small is sometimes the... Read more
>Tuning and Using a Spokeshave
Once you learn how to tune a spokeshave and use... Read more
>Template Routing
Template Routing
Router Skills: You’ll be able to quickly machine multiple parts... Read more
>The common wood screw
Go into any building supply store and you’re bound to... Read more
>Working with laminate
Learning to work with laminate is a skill that can... Read more
>Three Must-Have Router Bits
With so many bits available, which ones are the most... Read more
>Raised panel doors
Raised panel doors
There is more than one way to build this common... Read more
>Routing Bits, Jigs and Accessories
When you buy a router, you are investing in one... Read more
>Jointing & Surfacing
Milling wide long stock on a six or eight inch... Read more
>Router & Bit Care
Router & Bit Care
Keep your router and bits clean to avoid the problems... Read more
>Bent lamination
Bent lamination
Bent laminating is an easily acquired skill that will open... Read more
>Curved panel veneering
Tired of the look of flat doors on your cabinetry... Read more
>Cyclone Dust Collection for a Small Shop
Cyclone collectors provide an efficient and effective alternative to conventional... Read more
>Rail and Stile Doors
There are two things that woodworkers build a lot of:... Read more
>Routing Basics – Part 6: Specialty Bits
For jobs that are a bit out of the ordinary,... Read more
>The mighty mallet
The mighty mallet
Roughing out a large carving, or even a medium-sized one,... Read more
>Routing Basics – Part 5: Joinery Bits
Without a bit, the router is just a fancy paperweight;... Read more
>The Well-Dressed Board
How you prepare your stock will have an impact on... Read more
>Routing Basics – Part 4: Edge Profiling Bits
While square edges on furniture projects are commonplace, they don’t... Read more
>Patterns, Templates & Jigs
If you are looking to make your woodworking easier, faster and... Read more
>Routing Basics – Part 3: Straight Bits
The ability to quickly change the bit in a router... Read more
>Routing Basics – Part 2: The Router
The router is one of the few tools that comes... Read more
>Routing Basics – Part 1
Perhaps no more than forty or fifty years ago, grooving,... Read more
>Cutting dados & grooves on the table saw
Dados and grooves are one of the most basic joints... Read more
>Installing Hinges
Installing Hinges
While hinges may look different from each other, they all... Read more
>Gluing Techniques
Gluing Techniques
In this article we give you shop proven techniques to... Read more
>Installing drawer slides
Mechanical drawer slides offer some major advantages over shop-made wooden... Read more
>Choosing lumber
Choosing lumber
"A Board in the Hand is Worth Two in the... Read more
>The ins and outs of drawer slides
What holds your possessions and travels miles without ever leaving... Read more
>Easy steps to gluing
Successful gluing depends on many factors. Learn the basic steps... Read more
>Story sticks
Story sticks
Story sticks have been used in furniture making for a... Read more
>Lumber measurement
Lumber measurement
Most of us buy lumber that is either 'dressed' or... Read more
>Tuning a block plane
Table saws, jointers, planers and other machines are vital tools... Read more
>Canoe repair
Canoe repair
Few things are more Canadian than canoeing. Perhaps more than... Read more
>Scrapers
Scrapers
A card scraper is a thin piece of hard steel... Read more
>Power tool maintenance
Power tools face damaging heat and mechanical stress every time... Read more
>Inlay and banding
Inlay and banding
Adding inlay or banding to an otherwise plain project can... Read more
>Bandsaw circle cutting jig
This jig enables you to cut perfect circles of almost... Read more
>Planer and jointer dust hood
We show you the proper design of a hood for... Read more
>Heating your shop
Heating your shop
There are a few things to consider when heating a... Read more
>Shop lighting
Shop lighting
While it is possible to work safely in a cold... Read more
>Mitre saw: extreme make-over part 2
This article looks at collecting the dust that is ejected... Read more
>Mitre saw: extreme make-over part 1
The mitre saw is very difficult to collect dust... Read more
>Cane seating
Cane seating
This article leads you through the process of replacing a... Read more
>Belt/disc sander
Belt/disc sander
This older floor model belt/disc sander did not have any... Read more
>Carver’s vise
Carver’s vise
In this article, David describes the methods he uses for... Read more
>Reducing router dust
Reducing the dust from your router is no easy matter.... Read more
>Cabinet scraper alternative
Sooner or later, most woodworkers have the pleasure of using... Read more
>Featherboard alternative
This featherboard makes work at the table saw easier, safer... Read more
>CAD software review
CAD software review
This article explores seven CAD software packages in order to... Read more
>Restoring hand planes
Buying and restoring old hand planes is economical, educational, practical... Read more
>Design your own projects with CAD
There are really two parts to designing your own projects.... Read more
>Custom shipping container
Here is an easy and cost effective way to prepare... Read more
>No-hardware drawer pull
Have you ever wished that you could build a cabinet,... Read more
>The drill press
The drill press
The drill press is a very versatile machine to have... Read more
>Use your router as a biscuit joiner
Many projects need some form of joint. Biscuits not only... Read more
>The thickness planer
The thickness planer is one of the safest woodworking machines... Read more
>Holding it together
Holding it together
The glue selected to construct any project is as important... Read more
>Router spring removal for Porter-Cable 693
Many woodworkers have plunge routers mounted in their router tables... Read more
>Router spring removal for Dewalt 625
>The table saw
The table saw
Get practical tips on how to use your table saw... Read more
>Dust collector fans
Dust collector fans
Dust collector fans are material handling fans and, ideally, they... Read more
>Design time
Design time
Prior to the construction of anything, from china cabinets to... Read more
>Hitachi M12V router adjustment
Find out how easy it is to adjust your hand... Read more
>Radial-arm saw dust hood
This article looks at the construction of two different hoods... Read more
>Inlay in minutes
Inlay in minutes
You won’t believe how fast and easy it is to... Read more
>A marriage of textures
There are many skills and techniques involved in woodturning: skill... Read more
