Learn about the seven major types of shop adhesives
Woodworking Posters, from Canadian Woodworking, are free, easy-to-use reference guides covering essential techniques, tools, and shop safety.
Determining moisture content is critical for success in woodworking.
Woodworking is a lot of fun, as long as you don't hurt yourself. Download this handy poster that you can put up in your workshop for practical tips on workshop safety.
Marking tools are the most fundamental layout accessories in your shop.
Using the right tools and accessories you’ll greatly improve your precision, reduce mistakes and use your shop time more efficiently.
Learn about the basic types of specialty woodworking router bits.
A router equipped with a joinery bit makes quick work of repetitive joinery tasks.
Router Bits – Profile/Edge Treatment
Use these router bits with a fixed base or plunge router or on a router table to create simple or complex edge profiles.
The most frequently used type of router bit, essential for cutting grooves, dados and rabbets as well as for mortising.
The quintessential hand tool that every woodworker should learn to master.
These handy clamps help hold your stock securely on a benchtop.
Sharp tools make for easier, more accurate and more enjoyable woodworking; they require much less effort to use, and the cuts they make are more precise, crisper, and cleaner.
Buying a new table saw blade can be a daunting experience. Use our handy poster to help you select the right blade for the job at hand.
Hand saws are fundamental woodworking tools that enable you to make a wide range of precise cuts.
Learn about the ten major types of woodworking drill bits.
