Home » Top 10 essential power tools for the woodworker
These 10 power tools will make your DIY jobs easier to do and quicker to complete.
In the October/November 2023 issue’s Top 10 we looked at home improvement hand tools. In this issue we look at home improve­ment power tools. Combo kits can save you money, but avoid those that have superfluous tools you’ll rarely use. Buying tools from the same brand means you can swap out batteries and won’t end up with multiple battery chargers.
6. Stud Finder – A stud finder is the tool you want before you even think of hanging art on the wall, installing wall shelving or mounting a flatscreen TV. An electronic stud finder is a better choice than a magnetic model as it’s easier to use and more accurate. Look for a model that scans to about 1″ deep.
7. Cordless Glue Gun – They’re not only useful for crafts and children’s projects, you’ll also find copious jobs for them around the home and in the workshop. Avoid lightweight guns with a power cord as it tends to cause the gun to be unsteady and tip easily when set down on its stand.
8. Laser Measure – Most laser measures are accurate within 1/8″ up to about 30′, some up to 1/16″. A good quality unit will not only measure length, but also area, volume and indirect measure­ments. Some have a built-in inclinometer for finding angles.
9. Bench Grinder – If you dabble in woodworking or woodturn­ing, or like tinkering on the car, a bench grinder will enable you to grind cutting tools and shape or deburr metal. A grinder with a 6″ 120-grit grinding wheel and wire wheel is a good choice. A variable speed grinder, or one that runs at a lower speed, makes it less likely to overheat a tool edge.
10. Shop Vacuum – If your plans include large home improve­ment projects opt for a heavy-duty 12-gallon or larger vac that can suck up nails, sawdust and other debris. Most are corded. For those sticking with small jobs inside the home, a compact vac in the two-gallon range (corded or cordless) is the way to go.
