Power, precision and portability — pocket-hole performance redefined with the Kreg Rebel 20V Ionic Drive.
Pocket joinery is a simple, fast and reliable method of connecting two pieces of wood by driving a screw through an angled pocket hole into a mating workpiece, creating a strong mechanical joint without complex setups.
It’s popular with furniture makers and cabinet makers because it requires minimal tools, works well with basic shop equipment, and delivers accurate, repeatable results. Pocket screws provide excellent holding power, allow assemblies to be completed quickly without waiting for glue to cure, and make it easy to join parts in tight or awkward locations.
While pocket hole joinery as a concept has been around for centuries the modern pocket hole system as we know it today was invented and popularized by the Kreg Tool Company.
The new Kreg Rebel is a first‐of-its‐kind cordless, all-in-one pocket-hole drilling machine, combining the jig, drill and guide into a single handheld unit.
Manufacturer: Kreg Tool
Model: KPTRB100A
Price: $299.99 US (tool only)
Warranty: 3 year limited
Source: Where to buy
Key Features:
- Brushless motor
- 2,800 RPM drill bit speed
- Usable on material from 1/2″ to 1-1/2″
- Micro bit-depth adjustment
- Integrated dust collection
- GripMaxx anti-slip adjustable feet
- Includes: drill bit, driver bit, narrow rail guide, dust collection bit, vacuum attachment
Note: this tool is also available with a 4.0 Ah battery and charger (#KPTBRB100A).
So, what can you use the Kreg Rebel for? In my experience, quite a lot. It’s a go-to tool for building face frames, cabinet carcasses, drawer boxes, edge joints, and even quick shop jigs. Because the screws act as internal clamps, I can move or handle an assembly almost immediately — which is perfect when I don’t want to wait around for glue to cure. It’s especially useful when joining materials of different thicknesses or when working with plywood and MDF, where traditional joinery doesn’t always hold as well.
The Rebel brings several standout features to the table:
- A brushless 18V (20V max) Ionic Drive motor that delivers high torque and cordless convenience.
- The ability to drill pocket holes in material from 1/2″ to 1-1/2″ thick in a smooth, one-motion sequence.
- Tool-free micro adjustments for both material thickness and bit depth.
- A metal frame, integrated dust collection (with a bin and a vacuum hose option), a non-slip GripMaxx base, and a narrow rail guide for working with slimmer material.
In short, instead of juggling a separate jig, drill, and manual clamp setup, the Rebel merges everything into a single, self-contained tool.
With a standard pocket-hole jig, you typically dial in the thickness, clamp the material, drill with a separate drill, maybe switch bits, reposition for the second piece, and so on. With the Rebel, you set it once and drill — no extra drill required. I find setup noticeably faster, which is a real benefit when doing repeat holes or small production runs.
One of the biggest advantages for me is that the Rebel is cordless and portable, so I can bring it to the material instead of dragging awkward panels to a bench jig. That pays off when I’m working with large or heavy material, or when I’m installing cabinetry onsite.
In many cases, I don’t even need to clamp the material. The GripMaxx base (which has an array of narrow anti-slip ribs) and support feet hold the material surprisingly well. The anti-slip face on the fence also helps keep things steady. That said, for irregular material or when I need absolute precision, I’ll still use clamps. And no matter what, it’s important to apply firm downward pressure on the front handle — skip that and the bit can skate across the surface.
Setting up the Rebel is straightforward. A lever beneath the front handle sets the material thickness (from 1/2″ to 1-1/2″). On top, you’ll find the drilling depth stop and micro-adjust dial. When drilling into 3/4″ material, I simply match both the material setting and depth stop to 3/4″. That keeps the bit from fully breaking through.
Kreg also includes a narrow rail guide for securely drilling into slim material up to 4″ wide. You need to be a tad careful when drilling into narrow material — around 1-1/2″ and narrower — to ensure that the Rebel doesn’t rock from one side to the other as it rests on the material.
Remember that different material thicknesses require different screw lengths. For example, 3/4″ material typically calls for 1-1/4″ pan-head screws. Kreg offers screws from 1″ to 2-1/2″. I’ve found it more economical to buy the size I use most often in bulk (the 1,200-count boxes).
Eventually, you’ll need to replace the drill bit. Swapping it out is quick and tool-free — just remove the motor unit and slip in the new bit.
Pocket-hole drilling doesn’t create nearly as much dust as sanding or routing, but I still get better visibility (and a cleaner shop) by using a vacuum hose. The onboard dust bin fills after about a dozen holes, and debris starts spilling onto the work surface. The vacuum port doesn’t match Festool or Bosch hoses directly, so, like me, you may need an adapter.
Here are a few tips I’ve picked up using the Rebel over the past couple of months:
- Keep a spare 20V Blue Ion battery charged if you’re doing a lot of joinery.
- Apply steady downward pressure on the handle throughout the cut.
- Test your settings on scrap before committing to a project piece.
- Empty the dust bin often — chip build-up can throw off accuracy.
- Even though the base grips well, use a clamp for critical joints until you’re fully confident.
- When joining mixed materials (like plywood to solid wood), use the micro-adjust to fine-tune bit depth.
- Keep a backup drill bit and extra screws on hand — running out mid-build is never fun.
The Kreg Rebel 20V Ionic Drive Pocket-Hole Joiner stands out because it truly rethinks the pocket-hole workflow. By combining the jig and drill into a single cordless tool, it delivers real speed, consistency, and convenience for furniture building, cabinetry, and onsite work. For hobbyists and beginners, it’s an investment that genuinely reduces setup complexity and saves time on every project.
