FB
Top 10 Router Table Safety Tips
Router tables are versatile workhorses but, as with all machines, require great respect and care. Learn what their limitations are and you will find router tables helpful and enjoyable.
1. Don’t remove too much material per pass
This is possibly the most important safety tip. Router tables are very versatile, but the one thing they can’t do is remove a lot of material in one pass. Kickback and poor cut quality are the result of pushing the limits. Making several passes, adjusting bit height or fence position, or removing the bulk of the waste with another machine (I use the table saw for this purpose quite often) are safer options.
2. Use a solid fence
Any movement in a router table’s fence will at best ruin a workpiece or bit and, at worst, cause personal damage to the user. Ensure your fence is bombproof so that even very strong pressure will not cause fence movement. Add a clamp to either end of the fence when in doubt.
3. Use push sticks when necessary
Push sticks come in many shapes and sizes. Allowing fingers to come too close to the rotating blade is not safe. Push sticks also work well away from the bit when machining large, heavy pieces, as a push stick allows the user to better grip the workpiece. Dedicated, single-purpose push sticks can often be made.
4. Use featherboards
When routing profiles on long pieces a featherboard not only ensures the profile will be smooth and even, it maintains pressure near the bit, so your hands can stay a safe distance from the cutter. A featherboard also reduces the chance of kickback.
5. Understand what climb-cutting is, and when it can be used
The general rule is no climb-cutting. This is great for the beginning to intermediate woodworker, though there are times when climb-cutting can be employed. For starters, when a workpiece is hand-held, this is probably not the time to start climb-cutting.
6. Use ear, eye, and lung protection
Beyond the obvious safety concerns, I find ear protection especially important while working on a loud router table, as it allows me to focus on the operation at hand, rather than be deafened by a painfully loud router motor.
7. Ensure the router table doesn’t move during a cut
When using a router table, the workpiece is typically of small to medium size, but when dealing with larger, more cumbersome workpieces you may find yourself pressing into the router table’s fence more forcibly. The very last thing you want is for the entire router table to move. If it’s not heavy enough to stay put you can clamp it to something stationary.
8. Use infeed/outfeed supports if necessary
These third and fourth hands will help out greatly when routing longer pieces and allow your focus to remain near the cutting edge.
9. Understand the hazards of using large bits
Even though the RPM of a large bit may be the same as a smaller bit, a large bit’s rim speed is much higher. Burning the workpiece, as well as potential personal danger, are more likely with larger bits. They also need more clearance around the fence, so make sure to use a split fence to eliminate the gap.
10. Only remove small amounts of material with each pass
This is an important tip, and if it doesn’t sound familiar to you at this stage I suggest you reread this article, starting with tip #1. Use sharp bits? Buy a shaper instead? What are your router table safety tips? Share them online, at the end of this article.
Rob Brown - [email protected]
4 Comments
  1. Advertisement
  2. Hi Steve,
    Hard to say for sure, without seeing your setup. Emailing me a photo of your setup would help. Was your bit partially hidden / overlapped by your fence? This would mean while you move the workpiece from right to left the portion of the workpiece that is getting machined it AWAY from you. This would be the correct approach. It’s possible you had the fence set a few inches (or so) away from the bit and passed the workpiece between the fence and the bit. This would mean everything is switched and that you’re now machining the workpiece on the side that’s TOWARDS you. That would be dangerous.
    The general rule is that you want the portion of the bit that’s doing the cutting to be rotating in the OPPOSITE direction as the workpiece is moving. Otherwise you are “climb cutting” which can be very risky.
    Let me know your thoughts. Always happy to clarify further, if need be.
  3. Minimal experience with router or router table. Tried to rout a 10′ stair handle out of red oak on router table. Set for about 1/8″ per pass, went from right to left in front of table, but the 10 foot red oak flew. What did I do wrong?
  4. Hi Larry. It’s impossible to give a simple answer, as every bit is different. Each wood specie is different too. Harder woods require more passes. Also, moving the workpiece faster means the bit can take less material off per pass. Using 1/4” as a starting point will often work, but if the router is working hard, the finished surface of the pass is at all rough or you can otherwise see / hear a problem, reduce the depth of cut.
More Top 10 Lists
Top 10 sanding tips
Sanding is the first step to obtaining a...
Top 10 router accessories
Although some of these accessories are shop-made, they’re...
Top 10 most difficult things to do in a small shop
Spending time in a small shop is generally...
