Woodworking products to help you tool your shop.
Amana Ogee Raised Panel Door Making 3-Piece Set
3-piece set (#MD502) combines the 2-piece Stile & Rail cutters with one Horizontal Raised Panel bit with back cutter. With this set you can make raised panel doors in soft or hard wood from 3/4″ to 1″ thick. The cutters are made from high-quality micro grain carbide, and feature tri-foil brazing to ensure optimal bonding of the teeth to the cutter body. A.G.E. Pro-Series router cutters are engineered and manufactured to maximize performance at competitive prices. The AGE line also features a complete line of carbide tipped saw blades that are “Made in Germany.”
Why It’s Essential: With the MD502 you can make raised panel doors quickly and efficiently. Set-up is straight-forward, and the cutters produce smooth, clean cuts without chattering and tear out.
