With the wide selection of new products that come out annually, it can be overwhelming to have to keep up to date with everything that hits the market. To make this task easier on Canadian Woodworking & Home Improvement readers, we have assembled this list of “Hot Products” to kick off 2024.
More work, Less Pain
Kneel-It is a cleverly engineered support device designed to relieve strain and decrease injuries that come with prolonged kneeling. It helps reduce knee and back pain while increasing productivity at work or with projects around the house. Kneel-It rolls on hard indoor and outdoor work surfaces, and soft terrains. Built with special grip technology to help keep it stationary when idle, it has a padded ergonomic spring-loaded seat to provide intervals of rest and durable padded knee rests to ensure comfort while completing taxing jobs on-site or working from home.
Oryxtools.com
Supercharge Your Jointer with a Spiral Cutter Head
Elevate your benchtop planer to a whole new level of performance with the Sheartak Spiral Cutter Head. Say goodbye to the hassles of blade sharpening, intricate setup, annoying tear-outs, and the deafening noise that comes with using your planer. It’s time for an upgrade! Sheartak’s cutting-edge technology equips your planer with 40 carbide inserts, each boasting four cutting edges that maintain sharpness for an impressive 40 times longer. It’s compatible with a range of planers, including DeWalt DW735, Metabo DH330, Triton TPT125, King Canada KC-235PM, Craftex CX13HC, Grizzly G0889, Ryobi AP-1305 and many more. Sheartak offers a comprehensive selection of cutter heads in stock with options available for over 1,000 of the most popular jointers and planers. Now you can experience immediate improvements in your woodworking projects. Visit Sheartak.com or call 877-417-4327 for expert advice and to place your order today.
Compact Sanding for Tight Spaces
There are no other electric orbital sanders that match the power and finesse of the Mirka DEOS sanders. The new Mirka DEOS 343XCV
3″ × 4″ compact sander is small enough to work in tight spaces. A brushless motor delivers plenty of sanding power while its low design and comfortable grip keep you close to the working surface for optimal sanding performance. The DEOS 343 is particularly smooth to use thanks to its two operating modes and an extra 7,500 rpm step for finer speed adjustment. A full range of net abrasives and sanding sponges in the P36 to P600 range are available.
Mirka.com
Long Lasting Net Abrasives for Belt Sanders
Mirka Abranet, synonymous with net abrasives, features a net structure and is especially developed for the wood industry. They offer the widest selection of styles and sizes of abrasives and are among the least expensive. Abranet Max is the first net abrasive especially developed for belt sanders. They provide a high cut rate, resist clogging, deliver a more consistent surface finish and provide near dust-free sanding. These closed coating aluminum oxide belts are available in 2.5″ × 14″, 3″ × 18″, 3″ × 21″ and 4″ × 24″ formats in P80 to P180 grits. Increase your profitability and improve the quality of your finish with Abranet Max. Mirka.com
The Classic One-Hand Trigger Clamp with a New Twist
The new and innovative BESSEY 360° rotating trigger clamp (#EHKL360) is unlike anything else! The ability to optimize the handle position for clamping (or spreading) improves both clamping ergonomics and tool versatility by allowing you to position the handle optimally for each job. Additionally, you can clamp several EHKL360 clamps side-by-side in a confined space and rotate the handle 180° out of the way to allow room for the next clamp. This unique clamp is available in a clamping capacity of 6″, 12″, 18″, 24″ and 36″ with clamping pressure of up to 300 lbs.
BesseyTools.com
Einhell 18V Cordless File Belt Sander
The perfect tool for precise material removal and intricate detailing, the TE-BF 18 Li (#4461010) cordless file belt sander accepts 18″ sanding belts in both 3/8″ and 1/2″ widths. It delivers variable speeds from 250 to 1700 RPM and features tool-free belt change and belt alignment. The 90° swivelling sanding arm can be adjusted to suit any working position. Includes a suction adapter for connection to a shop vac and 12 sanding belts – two of each width (3/8″ and 1/2″) in 60, 80 and 120 grits. Battery and charger sold separately.
Einhell.ca
Einhell 18V 18-Gauge Cordless Brad Nailer
The FIXETTO 18/50 N (#4257796) cordless brad nailer is the ideal tool for making shop jigs and installing residential trim, securing backs and drawer bottoms, and assembling kitchen cabinets. It features maintenance-free PressAir technology, a robust gearbox that provides up to 60 impacts per minute, switchable single and bump-firing modes, tool-free depth adjustment, and tool-free removal of jammed nails. It takes 5/8″ to 2″ long, 0.04″ thick brad nails. Battery and charger sold separately.
Einhell.ca
Einhell 18V Cordless Biscuit Joiner
The model TE-BJ 18 Li (#4350631) cordless biscuit joiner can dramatically speed up furniture and cabinet assembly time. The solid aluminum design enables precise slot cutting. It provides an adjustable angle setting from 0° to 90° as well as a six-step quick adjustment of cutting depth. A spindle lock allows for easy blade change. Uses standard biscuit sizes up to #20. Battery and charger sold separately.
Einhell.ca
Einhell 18V Cordless Stick Vacuum Cleaner
Keep your home and your shop clean with the TE-SV 18 Li (#2347184) cordless stick vac. A motorized power brush and three-fold filter system results in high suction power. Choose between ECO and BOOST modes for the job at hand. Four LED lights illuminate dark hard-to-reach areas, while rubberized wheels protect your floors. Includes a wall holder and flexible crevice nozzle. Battery and charger sold separately.
Einhell.ca
Einhell 18V Cordless 3″ × 18″ Belt Sander
The cordless, brushless TP-BS 18/457 Li BL (#4466271) belt sander is perfect for quickly sanding rough surfaces and for levelling and shaping wood. It features a brushless motor, electronic speed control, tool-free belt changing, precise belt tracking adjustment and integrated dust extraction. The TP-BS 18/457 Li BL has soft grip handles for optimal handling over extended sanding sessions and delivers variable belt speeds from 394 to 820 ft/min. Includes a dust cannister, extraction adapter and three 80-grit sanding belts. Battery and charger sold separately.
Einhell.ca
Einhell 18V Cordless Compact Router with Fixed & Plunge Base
The TP-RO 18 Li BL (#4350413) cordless router features a brushless motor that delivers variable speeds from 10,000 to 30,000 RPM. It’s equipped with a 1/4″ collet and has dual stroke heights of 1.38″ and 1.58″. Other features include electronic speed control, fine-depth adjustment, multi-step turret stop, spindle lock and LED work light. Comes with an edge guide, edge guide holder, compass point, trimmer roller guide, template guide and spanners. Battery and charger sold separately.
Einhell.ca
Flexcut 3-Knife Starter Set
Flexcut knives are versatile, well-engineered tools, 100% North American made, assembled and sourced. The company’s commitment to quality and customer service make these knives a top pick of pro carvers, hobbyists and woodworkers around the world. We’ve packaged some of our most popular knives in the KN500 3-Knife Starter Set. The comfortable curved ergonomic handle allows for long periods of carving without hand fatigue. Includes KN12 Cutting Knife, KN13 Detail Knife, KN14 Roughing Knife, and Flexcut Gold polishing compound. $67.95
Flexcut.com
Flexcut SlipStrop
With several profile shapes all in one tool, this sharpening strop is an economical and easy way to keep your tools razor sharp. The PW12 SlipStrop has been specially moulded to allow for polishing and deburring the hard-to-reach areas on the inside of V-tools and gouges as well as the outside edge bevel. Includes a small 1 oz. bar of Flexcut Gold polishing compound and detailed instructions. $20.95
Flexcut.com
Flexcut Deluxe Starter Set
The SK108 Deluxe Starter Set contains profiles not included in any other interchangeable set. It’s a great way to add to your collection and save money. This set has everything a new woodcarver needs. It includes 16 interchangeable blades, cutting knife, quick connect ABS handle, and a power handle. There’s also a SlipStrop, gold polishing compound and an owner’s manual showing how to care for the tools. Plus you’ll find a free step-by-step instructional DVD for a great first project. $250.95
Flexcut.com
Laguna 14|BX Bandsaw
You’d be hard-pressed to find a 14″bandsaw with the combination of build quality, rich feature set, foot brake system and competitive price that the Laguna 14|BX bandsaw offers. It’s available with either a 1.75HP 110 volt or 2.5HP 220 volt TEFC motor. You get a full 12″ resaw capability. Other features include tool-free quick adjusting upper and lower ceramic guides, worm gear rack and pinion system for precise height adjustments, a massive 8″ × 13″ cast-iron trunnion, quick-release blade tension, a superb rip fence, and a cast-iron table that tilts 45° right and 7° left. Comes standard with a high-low re-sawing fence.
LagunaTools.com
Laguna F2 Fusion Table Saw
A good table saw is the heart of most wood shops. It’s one tool that will get used on almost every project you ever make, and it’s worth investing in a good saw for the speed and accuracy it will bring to your work. The Laguna F2 Fusion table saw has a range of practical features including a powerful 1.75HP TEFC Motor, trunnion mounted to the body not the table for improved accuracy and stability, cast-iron table and wings, permanently lubricated bearings, European Hi-Lo fence, and tool-less blade lock. Also features a digital readout showing the degree of tilt and a double window hairline readout. Value-packed and competitively priced.
LagunaTools.com
The Jobsite Table Saw That’s Small in Size and Big in Value
For avid DIYers, renovators and carpenters who don’t work exclusively in a workshop, a portable jobsite table saw is essential. It’s also ideal for hobbyist woodworkers who work in small shops where space is at a premium. The King Canada KC-5016C 10″ table saw has a powerful 15 Amp motor and large cast aluminum table with extendable rails that deliver up to 24-3/4″ rip capacity. The blade tilts 0° to 45° with detents for versatile angle cutting. The durable all-steel frame design is lightweight and designed to handle jobsite abuse. A folding stand (SS-5016) is also available.
KingCanada.com
Compact, Versatile and Powerful Belt and Disc Sanding
With an 8″ disc sander and 42″ sanding belt, the King Canada KC-770FX can handle a wide range of sanding, surfacing, grinding, cleaning and deburring jobs on wood, metal and plastics. It accepts either a 1″ or 2″ sanding belt for greater versatility. Features include a 1 HP direct drive motor, a quick-release lever for easy belt replacement and a solid cast-iron body and steel base for stability and vibration isolation. Includes both 1″ and 2″ × 42″ sanding belts, 1″ and 2″ belt platens, two 8″ adhesive sanding discs, mitre gauge and adjustment hex keys.
KingCanada.com
Portable Jointer for the Small Workshop
Whether you make furniture or cabinetry, your lumber needs to have one face flattened and an edge square to that face before you can thickness plane the lumber to its final dimension. Equipped with a 6″ width helical cutter head and 1HP motor, the King Canada KC-6HJC benchtop jointer gives a superior finish compared to jointers with standard steel blades. Depth of cut adjustments in 1/64″ increments are quick and easy to make and it has a large 4-1/4″ high fence that can be adjusted between 45° and 90°. With the KC-6HJC you’ll save precious floor space but won’t sacrifice surface quality.
KingCanada.com
Power, Capacity and Convenience
The King Canada KC-12HS-VS variable speed drill press provides you with the power, capacity and convenience needed to drill precisely positioned straight or angled holes quickly and easily. The 12″ benchtop model with a 1/2 HP motor is perfect for the small shop with limited floor space and for the home hobbyist. It accepts bit shanks up to 5/8″ diameter. You get a 580 to 3,200 RPM speed range, digital readout for precise spindle speed selection, dual intersecting adjustable laser guides for precise drill bit placement, and a positive depth stop for quick and easy adjustment of the spindle travel.
KingCanada.com
An Essential Addition to Any Workshop
A bandsaw is one of the most versatile shop machines woodworkers use. It’s ideal for ripping rough and dimensional lumber to size, re-sawing lumber into shop-made veneer, cutting curves, circles, irregular shapes, and cutting a variety of joinery. Equipped with a 1/2HP motor the King Canada KC-1002C bandsaw has a 9-1/2″ frame to blade cut capacity and a 4-1/8″ resaw capacity. It features an adjustable upper/lower ball bearing blade guide system, rack & pinion height adjustment system, quick-release lever blade tension system and tilting table with a built-in retractable extension table.
KingCanada.com
A Premium Feature-rich Mitre Saw That’s a Pleasure to Use
The King Canada 8380NS 10″ sliding compound mitre saw offers a lot of features and cut capacity that you would expect to find on larger 12″ models. It’s solidly built, durable, has excellent cutting capacity, is accurate, has good dust collection (connected to a dust extractor) and is easy to adjust. The carriage glides very smoothly on the rails without any wobble or vibration and delivers a 13-3/4″ straight cut capacity at 90°. The mitre scale is laid out in 1° increments and the rotating table has nine positive stops, while dual laser lights outline the cut line on both sides of the blade kerf for reliable cuts every time.
KingCanada.com
Front-Edge Banded Real-Wood Surfaced Shelf Boards
Columbia Forest Products’ Hickory Shelf Board is a beautiful, convenient solution for elevating your home’s organization or display needs. Now available at The Home Depot, this shelf board features a natural, unfinished hardwood face that can be stained, painted or clear coated. Whatever the finish, this formaldehyde-free, front-edge banded shelf board is ready to be transformed into a stunning piece that reflects your personal style! Plus, its lightweight 7-ply construction offers the strength and durability to support your treasured belongings. Available in 2′, 3′ and 4′ lengths.
HomeDepot.ca
The Ultimate Precision Joinery Machine
The PantoRouter is the safest, fastest, cleanest, most accurate, most repeatable and easiest joinery machine on the market! Cut your mortise and tenons, box joints and dovetails on a true joinery machine rather than the old-fashioned way using your table saw, bandsaw, router table and hand tools. You can set up and cut angled or compound-angled joints in minutes, virtually dust-free due to the incredibly effective dust collection hood. Go from setup to glue-up in under five minutes in most cases. Box joints and dovetails can be variably spaced, and custom templates can be shop-made to produce the perfect size and shape for your project. Custom furniture makers become more efficient, and hobbyists can create professional-looking projects with ease. Customers rave about PantoRouter’s thoughtful design, engineering and high-quality construction. Visit their website to see videos of the PantoRouter in action and learn more about how others are using this unique joinery machine.
PantoRouter.com
CXS 12 Cordless Drill
The CXS 12 delivers high power in a small package. Fully loaded with compact batteries, a magnetic bit holder, LED light control, high/low range, an electronic drive clutch and a removable belt clip, it’s conveniently compact for tight spaces and daily use. This 12V drill is neatly packed in a Systainer for added portability.
FestoolCanada.com
TSV 60 K Track Saw
A complete system for premier processing, the TSV 60 K enables precise work for the most demanding tasks, no matter the jobsite. Offering the perfect cut in a portable format, it is “The Perfectionist” of the Festool family of track saws. Comes with a built-in scoring blade that can be adjusted for absolute precision. Quality, splinter-free cuts are practically guaranteed. The brushless EC-TEC motor makes it virtually maintenance-free and extremely powerful. The high-speed motor enables effortless work progress with less force.
FestoolCanada.com
KAPEX KSC 60 Cordless Sliding Compound Mitre Saw
Produce unbeatably precise crosscuts in an enormous range of applications with mitre angles of up to 60° on each side and bevel angles of up to 46° right and 47° left. The twin-column guide on the KSC 60 with two bearings ensures that the saw blade is guided smoothly. In conjunction with the dual battery system, the brushless EC-TEC motor provides virtually unlimited endurance. And finally, clever details such as the variable speed, saw blades for every application, bevel, ergonomic underframe and dust bag create the ultimate experience in precision, durability and performance.
FestoolCanada.com
TS 60 K Plunge-cut Saw
With more capacity, more function and more power, the TS 60 K Plunge-Cut Saw redefines possibilities for carpenters, woodworkers and remodelers. The TS 60 embodies absolute precision and power with integrated features that help minimize risk so professionals can focus on the job at hand. Key features include durability as the latest-generation EC-TEC motor is virtually maintenance-free, providing extreme power and speeds. Also, it offers versatility across applications with a cutting depth up to 2-7/16″ (62mm) and improved functionality and safety with industry-first Kickback Stop technology.
FestoolCanada.com
TXS 18 & CXS 18 Cordless Drills
An alternative to the CXS 18, the TXS 18 replicates its features but in a T-shaped design. Both 18V power cordless drills, equipped with the CENTROTEC system and Fast Fix interface, facilitate easy swapping of attachments. The compact, practical yet powerful, 18V power CXS 18 drill-driver boasts a lightweight, C-shaped design perfect for on-the-go usage. Compatible with the existing 18V Festool drill system, the CXS 18 is built for user convenience, featuring a belt clip for ambidextrous usage and an integrated bit holder for easy storage.
FestoolCanada.com
CSC SYS 50 Cordless Table Saw
Portable and precise, the CSC SYS 50 cordless table saw produces shop-quality cuts on the jobsite while being so compact it fits into a Systainer. Impressively versatile, the saw produces parallel cuts of up to 11″ (280 mm), a crosscut width of up to 17-3/4″ (450 mm) and bevel cuts of -10° to 47°. Precise cuts with the push of a button. Set the height and angle accurately to a tenth of a millimetre (1/256″) with unique digital operation — more exact than any tape measure.
FestoolCanada.com
