Hot Products 2019
Hot Products 2019
With the wide selection of new products that come out annually, it can be overwhelming to have to keep up to date with everything that hits the market. To make this task easier on Canadian Woodworking & Home Improvement readers, we have assembled this list of “Hot Products” to kick off 2020.
The Ultimate Circular Saw
The Cuz D Straight Flush Cut Saw #B3835 is a revolution­ary design that allows flush cutting, under cutting, and cutting into 90° corners – with a maximum cut depth of 3-1/8″. With the Cuz D you can cut into and out of corners; set the blade to a negative 5° bevel and the blade is lifted away from the wall, so finished walls are not dam­aged; gang cut two 2″. 4″ boards in just one pass; and cut a 6″. 6″ beam with just two passes. This saw is built to compete, out-perform and out-last. Available exclusively in Canada at Busy Bee Tools.
BusyBeeTools.com
cuz-d
Published December 2, 2019 | Last revised September 29, 2023
