Welcome
The Difference: Mineral spirits and paint thinner
Mineral spirits and paint thinner are often thought to be the same thing, and while they are closely related solvents with over­lapping uses, there are some key differences in terms of purity, odor and performance.
Mineral spirits are a petroleum-based solvent that’s more highly refined than general-purpose paint thinner. They’re com­monly used for thinning oil-based paints and varnishes, cleaning brushes and tools, and degreasing surfaces in both wood­working and painting. One of the biggest advantages of mineral spirits is that they produce a relatively mild odor, especially in their odorless or de-aromatized form. They evaporate more slowly than paint thinner, which can be beneficial when you want to reduce brush marks or allow more open time when working with finishes.
Mineral spirits
Mineral Spirits – More highly refined than paint thinner, mineral spirits produce a relatively mild odor and evaporate more slowly than paint thinner.
Paint thinner, on the other hand, is a broader term that generally refers to a less refined solvent — often a lower-grade form of mineral spirits or a mixture of various petroleum-based solvents. While it performs many of the same functions as mineral spir­its, paint thinner tends to have a stronger, more pungent smell due to its impurities. It also typically evaporates faster and is usually less expensive, making it a more economical choice for cleaning tools or removing grease and grime from surfaces.
Paint thinner
Paint Thinner – Tends to have a stronger, more pungent smell than mineral spirits due to its impurities. It usually evaporates faster and is usually less expensive than mineral spirits.
In practice, use mineral spirits for their more consistent performance and lower odor, especially when working in enclosed spaces or when a clean finish is important. Paint thinner may be more appropriate for rougher cleanup tasks or where cost is a concern and odor isn’t a major issue.
It’s worth noting that while all mineral spirits can be considered a form of paint thinner, not all paint thinner is pure mineral spirits. For the cleanest results and safest handling, especially when working with fine woodworking finishes, mineral spirits — particularly the odorless variety — are usually the better choice.
Published April 13, 2026 | Last revised April 13, 2026
