Sheet goods essentials
There are pros and cons to every type of sheet good. To avoid confusion when deciding what type to use, learn what the options are, and when and how to use the sheet goods properly.
Storage and wall units are some of the largest projects a woodworker will undertake. They can certainly be built from solid wood, but the added labour and expense of solid wood means sheet goods usually make a lot more sense as a building material. Solid wood is great for trim, mould­ing, edging material, door frames and other details involved with storage and wall units, but sheet goods usually make up the bulk of large projects like these.
Many people think sheet goods are just poor-quality furniture and built-in options when compared to solid wood, but this isn’t the case. Learning when to use sheet goods instead of solid wood is an important part of woodworking and DIY knowledge.
Overall dimensions
Sheet goods are, generally speaking, a synthetically assembled sheet of material that can be machined with woodworking and DIY machines and tools. They’re usually made up of wood of some form or another. They’re most often found in 4′ × 8′ dimen­sions, though most Baltic birch plywood is also available in 5′ × 5′ dimensions. A big box store will likely have just 4′ × 8′ sizes, though they will often stock smaller panels cut from these larger panels that are 2′ × 4′, 4′ × 4′ or even 1′ × 8′. These smaller sizes make transportation easier, and are helpful for people with small shops and homes.
It’s always more cost effective to purchase a whole sheet, if you need it, rather than piece one together with parts. Some retailers will have a saw on hand so you can have them make a few cuts. Just remember, these cuts aren’t always super accurate, so leave yourself a bit of wiggle room.
Sheet goods are available in different thicknesses, as well. The most common thickness available at a big box store is 3/4″, though 1/2″ and 1/4″ are also quite common. If you go to a large lumber­yard that stocks sheet goods, you’ll likely also find some types of sheets 3/8″ and 5/8″ thick. Special ordering sheets will give you access to sheet goods over 3/4″ thick, though you may have to order a large quantity.
Thickness Can Be Deceiving
Thickness Can Be Deceiving – This piece of 3/4″ Baltic birch measures about 1/16″ less than the stated dimension. Always measure accurately if you’re machining a joint that’s based on the thickness of the piece of sheet good you’re using.
Some of these thicknesses will be very close to exact, while oth­ers will be about 1/16″ off, or more. For example, 3/4″ plywood, no matter what type you get, is often about 11/16″ thick. This is common across the different thicknesses.
There are a number of pros and cons for each type of sheet good, but before we get specific, let’s cover some general characteristics of all sheet goods.
Great for Shop Fixtures
Great for Shop Fixtures – Here’s one of Brown’s shop fixtures, with a sheet good base. Sheet goods have many advantages over solid wood in this setting.
Less seasonal movement than wood
The size of a piece of solid wood fluctuates as humidity levels change with the seasons. Sheet goods do this, too, but much less so. You generally don’t notice a difference in the dimensions of a sheet good if it’s in a piece of furniture and it’s cut to a relatively small size.
The main time I notice a sheet good moving with the seasons is when larger panels are used in a wall or storage unit and you’ve added some form of caulk to fill a small gap between the sheet good panel and the wall, ceiling or floor. This is especially true on the first year of its life, as it might have been slightly on the humid side when you bought it, and therefore might have been on the larger side when it was machined and installed. The dry condi­tions of an indoor room cause the sheet good to lose much of that moisture and shrink slightly. I find another bead of caulk often cures that problem for good, though you might find yourself need­ing to touch it up once in a while.
Great cores
The fact that sheet goods don’t move much at all means they can be more easily used in many situations. When building with solid wood you need to consider grain direction and in which direc­tion the workpiece will move with the seasons. This is only a small problem when using a sheet good to create a large workpiece.
The lack of seasonal change in dimension is one of the reasons sheet goods are often used as a core for veneering. Another benefit of sheet goods as it relates to veneering is that some sheet goods remain very flat and stable throughout their lifetime and make a good substrate for veneer. The edges of sheet goods pose problems when veneering, however, but we’ll get to that later.
Use them in the shop, too
Sheet goods are also great for shop fixtures. They’re relatively cheap and provide the user with a larger surface to use. Some types of sheet goods can hold a screw much better than others and are durable enough for shop use. Gluing fences and other things to most sheet goods results in a fairly strong joint.
Adding 1/4″ thick solid wood edging to sheet good jigs and fix­tures will keep them strong and sound for even longer, as the solid wood protects their edges.
Be careful of their edges
Generally speaking, sheet goods are made up of layers of some sort. There are inherent weaknesses to the different types of sheet goods that must be considered when building with them. The den­sity of particleboard and MDF is lower in the centre of the board’s thickness and plywood can delaminate along some of its lamina­tions. Both of these weaknesses mean that driving a screw or other fastener into the edges of a sheet good can quickly become prob­lematic, resulting in a split workpiece. There are a number of ways to protect against the workpiece splitting, but none of them will give you a joint as strong as if it had been made with solid wood.
Predrilling will ease the internal stress a screw or fastener builds up, and will reduce the chance of splitting, but it doesn’t leave you with a guaranteed strong joint; just a somewhat weak joint that hasn’t split.
Weaker Centre
Weaker Centre – This is a piece of 1″ thick particleboard. You can see the areas nearest both surfaces are denser than the centre of the board. This leaves the surface smoother and less likely to dent, but it also leaves the centre of the board more prone to splitting if the edge is screwed into.
Adding solid wood edging to a sheet good workpiece will offer some grip for a fastener, and also go a long way to keeping the sheet good from splitting, but it’s far from a cure-all. The thickness of the edging will affect the results; a thin edge will offer a small amount of screw-holding benefit, while a thicker edge will offer much more, but there are limits. A wood-to-wood edge joint is very strong, while a wood-to-sheet good joint ranges from being some­what weak to a lot weaker.
Pre-Drill for Hardware
Pre-Drill for Hardware – If you’re going to drive screws into the edges of any sheet good, pre-drill carefully and don’t overtighten the screw. Just know that the screws lose a fair bit of holding power in the edges of sheet goods and splitting may occur, loosening the grip the screws have on the material.
It’s also possible to cut mortises into the edges of sheet goods and glue in strips of solid wood so screws can get a bit better grip on the workpiece, but that’s not always an easy process to machine accu­rately, nor is it going to provide a bomb-proof joint.
When all is said and done, edge joints that include a sheet good aren’t nearly as strong as edge joints with solid wood, so there are limits to how much stress you subject them to and how the different stresses are applied to them.
Add a Wood Tenon
Add a Wood Tenon – If you want to increase the gripping and staying power of screws driven into the edge of a sheet good, you can start by routing a mortise in the board’s edge and gluing in a solid wood tenon. The tenon can be trimmed flush with the edge’s surface and you can further finish the edge as needed.
Screwing into their faces
Driving a screw into the face of a sheet good is going to give you better results than driving a screw into its edge, but there are still things to consider when doing so. Plywood, with its cross-grain construction, naturally holds itself together better than parti­cleboard, MDF and thinner sheet goods like wiggle wood and hardboard. Plywood is not only less likely to split, but it’s obviously going to be more successful when it comes to keeping a screw in place.
A Bubbling Mess
A Bubbling Mess – If a screw in a sheet good like particleboard or MDF is pulled out it will likely leave a large, damaged area around it. Particleboard and MDF are more likely to do this than plywood.
Tensional strength on a screw that’s driven into particleboard or MDF will be lower than shear strength, meaning if there’s a force pulling the screw directly away from the sheet good it’s more likely to fail than if the force is sideways.
Also, don’t overtighten a screw that you’ve driven into any type of sheet good, especially particleboard and MDF. Strength is drasti­cally reduced the moment the fibres around the screw start to give away which happen more easily with the softer fibres in particle­board and MDF.
Cores and faces
Generally speaking, most sheet good cores are available with or without a face and back veneer. For example, it’s possible to buy a sheet of particleboard with or without face and back veneers adhered to it. The main exception is plywood. Some types of ply­wood are available in many different domestic and exotic species, while others aren’t. Sheathing and Baltic birch plywood are two of the most common examples. Both will have a layer of wood on the face and back, though you won’t be able to specify what species that is. When it comes to sheathing, it’s a softwood like spruce. With Baltic birch, the species you’ll get is birch.
Adding a face and back veneer to a sheet good increases the price substantially, though it means you can use that sheet good for a nicer finished piece of furniture or cabinetry, as opposed to either having to veneer it yourself or only using it for a struc­tural part or in a location like an unfinished basement or garage. There’s nothing saying sheathing plywood isn’t strong enough for a living room wall unit, but because it’s much rougher and less attractive than other types of sheet goods, it’s very rarely used for this purpose.
Plywood options
When it comes to plywood, there are many different varieties on the market. The quality, price and end use of these different plywoods range quite a bit. You also might be able to easily find one type in certain areas of the country, while not in other areas. If you’re at all confused about what type of plywood your local retailer carries, speak to a salesperson about your needs so they can steer you in the right direction.
Keep them dry
Sheet goods are generally meant to be used indoors. Water will very quickly ruin most sheet goods, causing them to swell up, weaken dramatically and fall apart. While plywood will stand up to water better than other sheet goods, it’s not meant for continuous water contact. The best option for outdoor usage is marine grade plywood, which is water and decay resistant, though it still needs to be finished and maintained properly to stand up to the elements for any length of time.
It’s a good idea to keep MDF and particleboard out of bathroom vanity construction. I’ve also seen some kitchen cabinet manufac­turers use plywood for cabinets around the sink and dishwasher areas just in case something goes wrong with the plumbing.
Protection
Handling sheet goods can be very hard on the hands. Whether it’s slivers from plywood, cuts from melamine or just the sheer weight of lifting and moving these sheets around, a decent pair of gloves will save the day. For less than $20 you’ll find something at your local hardware store that will fit nicely, grip sheet goods and protect your hands while you work.
Good Protection
Good Protection – Gloves aren’t expensive and do a great job protecting your hands from slivers, splinters and cuts while handling sheet goods. Freshly cut melamine is very sharp, while plywood can be very prone to producing splinters. Using gloves, even just during the breakout phase of machining, is a great approach to protecting your hands.
Dealing with the edges
Most sheet goods have edges that will need to be covered in order to blend in with the rest of the piece of furniture or cabinetry, unless the edge is either hidden inside a joint like a dado or groove, or will never be seen, like the back or side edges of an adjustable shelf.
There are three main approaches to covering edges. None of them are necessarily better or worse than the others. They all have their pros and cons, so select the best approach for you in each situ­ation you’re using them.
Solid wood headers – If you’re building a desk, for exam­ple, adding 3/4″ thick × 1-1/4″ wide solid wood headers around all four edges of a plywood top would work nicely. The solid edges will cover the unsightly edges of the top, will protect those four edges from wear and tear, and the solid wood edge can also be routed to add a nice visual detail.
Solid Wood Header
Solid Wood Header – This is a small pantry cabinet Brown built years ago. Although the top is tiled, the solid header is very similar to use on a sheet good top. The header gets wrapped around the top and glued in place, then the front edge can be routed to give you the look you want. This approach protects the edges of the sheet good, allows you to add a routed visual and even gives you the opportunity to create a thicker looking top by adding headers that are wider than the top is thick.
On the downside, this takes more solid wood material, can be tricky to glue up nicely and you have to be careful how the upper edge of the headers mate with the upper face of the sheet good. As long as the header finishes above the face of the sheet good it can be flushed up with the sheet later. Just be careful at that point, because using tools to flush the header with the sheet good may cause you to sand or plane through the veneer on the sheet good, causing major problems.
Solid wood edging – Instead of using a large header, a strip of solid wood about 1/4″ thick can be added to the edge of a sheet good to offer protection and a visually clean edge. This approach is usually quicker and easier, though it doesn’t offer many routed edge options. Adding these edges to the workpieces before assembly means you can more easily rout or plane them flush, though that may cause challenges near the corners of mating parts that need to be considered. Stopping edging a certain dimension before the end of a workpiece might be needed.
Solid Wood Edging
Solid Wood Edging – Once the solid wood edges are machined to thickness (between 1/8″ and 1/4″ thick usually work well), they can be glued to the edge of the sheet good with masking tape. It’s often a good idea to lightly sand or chamfer the two outer edges of the edging so they don’t cut the tape while the tape is being applied.
Trim Them Flush
Trim Them Flush – A router, set up with a straight bit and auxiliary base, will make quick work of flushing the solid wood edges with the sheet good. Set the height of the bit so it’s flush with, or just slightly above, the lower face of the auxiliary fence so that when you move the bit over the edge it will be trimmed off almost perfectly flush with the face of the sheet good.
Iron-on tape – Iron-on edge tape will do a good job at cover­ing the edges of exposed sheet goods. Iron-on tape is available in many species of real wood and many colours of melamine so you can likely match your project exactly.
Add Some Heat
Add Some Heat – Using an iron to apply wood or melamine tape isn’t complicated, though practicing on some scrap first will give you a good sense of what iron temperature is best and how long to leave the iron in contact with the tape. Use a shop-made push block with a rounded edge to press the tape firmly against the edge of the sheet good right after you remove the iron from the tape.
It’s not hard to apply, though if this is your first time doing so, it’s good to practice on some scrap. Too much heat, or applying the correct amount of heat for too long, will cause burns. Too little heat, or applying the correct amount of heat too quickly, will leave you with an edge that’s likely to fall off. As a general rule, apply enough heat to cause the tape to stick, then leave the iron in contact with the tape for another second or two. I generally use a fairly high setting on my iron, though irons may differ in how hot their hottest setting is.
As you move the iron across the edge, use an object (I use a shop-made push stick that’s rounded at the end) to press the iron-on edging down. Running the push stick over the edge a few times is good assurance to keep it down until the heat-activated adhesive cools and sets.
Cut Melamine Flush
Cut Melamine Flush – A reasonably sharp plane iron will make quick work of flushing the edges of the melamine tape to the face of the sheet good. A word of warning: If the plane iron is very sharp it might dig into the face of the sheet good, damaging the workpiece.
Ways to trim the edges differ, depending on whether you used a melamine edge or wood edge. Melamine can be trimmed with a plane iron set flush on the face of the sheet good. A file with a rect­angular cross section and teeth on its edge can trim wood tape flush with the workpiece. In both cases, practice makes perfect. Some light sanding after the edges are trimmed will leave you with an attractive edge that’s ready for the next step.
File Wood Tape Flush
File Wood Tape Flush – The simplest way to flush wood edge tape is with a file. Ensure the file has teeth on its edge, so it will cut sideways. With some pressure to keep the face of the file flat against the workpiece, angle the file and move it downwards and forwards with each stroke, removing an inch or two of tape with each pass.
Ease Some Edges
Ease Some Edges – A rough sanding block will go a long way to easing any edges that don’t need to have a crisp edge. This can be for any edges that will be captured in a dado, rabbet or groove, the rear or side edges of an adjustable shelf, as well as some other instances. Brown has even very lightly eased butt joint edges, even if that means there will be a very small, yet even, gap between the parts. This approach reduces chipping before the parts get assembled.
Don’t be afraid
If sheet goods are new to you, this is probably a lot to take in. Like any other material, there’s a time and place for each of these sheet goods and knowing when to use them is an important skill to have. Sheet goods can make many larger cabinet and storage projects much easier and faster to complete.
Watch the Edges
Melamine, like any material, has its pros and its cons. One of its cons is that it’s prone to chipping when machined and these chips are very noticeable in the finished project. Stack the deck in your favour and use a sharp blade, though that alone is unlikely to solve the chipping problem.
Chipped Edges
Chipped Edges – On the left is the underside of a workpiece that was cut in one pass. Chipping along the underside of the material is very common and will be a problem in any workpiece that’s visible from both sides. The workpiece on the right shows its underside once it’s been double cut.
Some of these parts only need a clean edge on one face of the mate­rial. An outer gable that will be against a wall will only have its face seen, so any chipping can be positioned facing the wall. For parts like vertical dividers, that’s a trickier situation, as they’re visible from both sides. In this situation I use what I call a “double cut” technique. A scoring blade takes care of this in a production shop setting, but few of us have that luxury at our disposal.
Double Cutting
Double Cutting – If you adjust the blade height so it only cuts about 3/16″ into the underside of the material the exit angle of the blade is close to parallel to the underside of the workpiece and is far less likely to cause any chipping. Once the first scoring cut is made you can raise the blade and cut all the way through the workpiece.
First, a bit of chip formation science. Generally speaking, the underside of a workpiece will chip out as the blade exits the workpiece and dam­ages the lower face. This is in large part because the exit angle of the blade is too close to perpendicular to the lower face of the workpiece. A strange thing happens when the exit angle gets closer to parallel with the under­side of the material – it stops chipping. If you make the first pass with the blade set to about 3/16″ high, chipping will virtually disappear on the underside of the workpiece. The workpiece can then be re-cut, with the top of the blade above the workpiece. This should drastically reduce chipping, maybe even eliminate it. I’ve also seen people do two half passes with the blade set ever so slightly higher than half the thickness of the mate­rial. They flip the workpiece over after the first cut and run the same edge against the fence. Try both approaches and see what works best.
Clean Edges
Clean Edges – After the scoring cut has been made in the workpiece, the freshly cut edges on the underside of the workpiece should be free from chips.
I also like to lightly ease the fresh cut edges of melamine once it’s been machined unless I’m going to apply iron-on tape to the edge. Think of the two sides and one back edge of an adjustable shelf. The edges of melamine can chip easily, unless you ease them. This may leave a very slight gap between mating parts, but it’s much better than medium-sized chips. Easing some of the edges will also greatly reduce cuts on your hands while you work.
Types of Sheet Goods
Particleboard Core
PROS
• cost effective
• remains flat, unless weighted
• medium weight
• smooth enough faces to apply veneer to
• commonly available
CONS
• medium screw-holding strength in its face
• weak screw-holding strength in its edge
• not overly strong or durable
• very poor when wet
• faces must be veneered to look good
• edges need to be covered to look good
• prone to splitting if used improperly
Melamine-Covered Particleboard
PROS
• the melamine surface is surprisingly durable and water resistant
• no finish is needed, speeding up the project considerably
• available in different colours and patterns
• very cost effective
CONS
• the particleboard core is very susceptible to water damage
• doesn’t have the “wood” look some makers are after
Medium-Density Fibreboard (MDF)
PROS
• smooth faces are good for veneering
• fairly stable in terms of flatness
• fairly cost effective
• edge composition is even and can be routed and primed / painted
CONS
• heavy
• very weak when wet
• faces usually need to be veneered to look good, though an opaque finish can be applied to them with success
• depending on the look you want, edges usually need to be covered to look good
• edges chip somewhat easily and are sharp while machining
• faces can swell near where a screw is driven
Baltic Birch
PROS
• both faces and edges can be finished as-is
• lightweight to handle
• strong overall strength
• smooth surface that can be veneered
• strong screw-holding strength in face
• can handle a small amount of water without dramatically weakening, though it’s far from waterproof
• good dimensional stability
• often available in 4’x8′ and 5’x5′ sheet sizes
CONS
• easily warps
• expensive
• slivers while machining are common
• sometimes large splinters form at the edges, causing an uneven look
Furniture-Grade Plywood
PROS
• can easily be used to make quality furniture and storage cabinets
• screw-holding strength in face is relatively strong
• fairly lightweight to handle
• fairly high overall strength
• available with many different species of face / back veneers
• available in many different qualities and end uses
CONS
• easily warps
• expensive
• face and back veneers can be thin
• slivers while machining are somewhat common
Sheathing Plywood
PROS
• cost effective
• fairly strong
CONS
• faces are unsuitable for furniture construction
• doesn’t stay flat
Marine Plywood
PROS
• water and decay resistant
• appropriate for outdoor projects like signs, decks, furniture and marine applications
CONS
• expensive
• not completely waterproof, so must be treated properly and cared for
• harder to find
Flexible Plywood /Wiggle Wood / Flexi Ply
PROS
• constructed so it will easily flex / curve in one direction
• can be laminated with multiple layers to produce fairly tight, strong curved workpieces
• 4’x8′ sheets are constructed so they will either roll into a 4′ long roll or an 8′ long roll
CONS
• easy to buy the wrong orientation
• hard to handle full sheets, as they bend very easily
• multiple layers usually need to be built up to create parts strong enough for lasting furni­ture, though single layers are sometimes used in curved parts of a house’s interior (think some non-structural curved stair parts or curved bulkheads)
Hardboard
PROS
• high strength-to-weight ratio
• resistant to splitting
• good material for cabinet backs
• available with or without a melamine face
CONS
• only available in thin sheets
• too thin to properly hold screws or other fasteners
• can be hard to handle full sheets, as it’s flexible
Photos credit: Rob Brown
Published June 4, 2024 | Last revised June 4, 2024
3 thoughts on “Sheet goods essentials”
  1. Hi Rob, I was planning to print most of these pages, io to have reference whenever I need to look at it again.
    However, it doesn’t take kindly to my printing instructions. I am a subscriber. Any suggestions ?
  2. Thoughts on the Sheet goods essentials
    Hey Rob
    I really enjoyed your piece on Sheet Goods, but I noticed you didn’t touch on the metric system. It seems like a big miss!
    I am a late Boomer so I use a hybrid of Imperial and Metric, when building cabinets, tables etc. Most of the sheet goods I buy are in metric thickness and are sold like this 4’x8′ x 18MM actual 1220×2440 x18mm
    As we’re working more globally, using metric measurements can make a huge difference. It helps avoid confusion and keeps everything accurate, which is super important in our hobby.
    It’d be great to see a conversation about how switching to metric could help us all work better together.
    Cheers,
    Mark Bergasse
