Crazy for cauls
Blog by Rob Brown
cauls
Clamping cauls aren't the most amazing shop project ever, I will admit. But they are a small but important part of having an operating workshop.
Cauls are also very easy to make. Before I get into cauls, let me bring you up to speed on what I’ve been doing in the shop lately.
A few weeks ago I finished a large job I’ve been working on for about four months –  a Baltic birch kitchen, bar top, large vanity and recycling cabinet. Everything turned out well and the clients are happy, so I’m happy. It’s always a challenge juggling a large job like this with my magazine duties, but such is life.
Large jobs seem to move so slowly, especially towards the end of the project. It’s during these last few weeks that I always wish I had time to do so many other things, but instead I’m juggling small details to ensure the finished project turns out well, all the while wondering why I’m not done with the project by now. Once I’m finished a large job it’s nice to clean up the shop and do a few small projects that have been put off for  the past few months
Cauls: a nice small project
While cleaning up I ended up with (not surprisingly) a whole bunch of smallish Baltic birch offcuts. This reminded me of a few clamping operations over the past few months when I wished I had some clamping cauls that weren’t covered in glue and were a bit longer. A tiny little light bulb went off in my head and I got to work.
Fifteen minutes later I had tossed out a bunch of old cauls and made a few different sizes of brand-new Baltic birch cauls. They all had their edges sanded smooth and were sitting very neatly on the shelf. It was a nice feeling to be able to finish a job in about 15 minutes. I even had the clarity and forethought to rearrange the cauls so the ones I use most are closest, while the ones I seldom use are a bit farther away. Wow, was I in the zone that day.
Interestingly, the cauls I use less often are cauls I enjoy using the most. I have some slightly curved cauls (of a few different radii) that are offcuts of curved bending forms I’ve trimmed to about 2″ long. They’re great for bent lamination work and other times when I work with curves. I also have notched cauls that are good for a wide variety of weird and wonderful situations. Using them on the outside of 90° corners to provide a better clamping surface is one option. I’ve also used them on outside corners that aren’t 90°. Another time I use these cauls is when I’m positioning the cauls across a glue line and don’t want to glue the caul to the project. The notch goes right over the glue line. Some of these notched cauls have dowels running across the grain, as when you apply clamping pressure in some situations they tend to split. The dowels tend to keep the cauls together pretty well.
Using cauls
In case you’re not quite sure what I use all these cauls for, they’re usually used during a glue-up to protect the workpieces and to disperse clamping pressure over a wider area. I often make them out of solid wood, as it’s pretty durable, rigid and comes in thicknesses larger than 3/4″, but since I had a bunch of Baltic birch plywood pieces kicking around I made a few sizes, rather than toss them in the garbage.
I may use cauls on their edges, as that approach is best for dispersing clamping pressure, but a 3/4″ caul can sometimes add problems to an already tricky glue-up. Thinner cauls have the tendency to not sit flat against the workpiece, which can cause a host of problems. Every situation is different, which is why I have so many shapes and sizes nearby. Although you can’t see them in the photos, I have many cauls between 24″ and 60″ in length, which are great for clamping up larger panels or cabinets.
Next time you have a few offcuts, cut them to a manageable size, ease their edges and give them a dedicated shelf to call home. Before you know it you’ll have a helpful collection of clamping cauls you’ll reach for regularly.
Caul Me Crazy
These are most of my smaller cauls. They range in sizes and materials, but come in very handy. Notice the 3/16" x 3/16" x 3" long strips of walnut I have in the aerosol spray can lid on the C-clamp shelf above the cauls. These are placed underneath pipe clamps while in use so the pipes don’t come into contact with the wet glue lines and stain the piece. This is especially problematic when working with light-coloured woods like maple.
cauls
Getting Fancy
These are some of my notched and curved cauls, which are great for so many unique clamping situations. If you look closely you can see a few dowels extending through the uppermost notched caul.
cauls
Published:
Last modified: May 4, 2023
Rob Brown - [email protected]
1 comment
