SPONSORED
The Festool SYS-AIR is a compact, portable air filter designed to enhance air quality in workshops and job sites by capturing fine airborne dust that traditional extraction systems might miss. Housed in a Systainer³ M437 format and weighing approximately 22 lbs (10 kg), it offers both mobility and seamless integration with other Festool systems.
Key Features:
Powerful Airflow: Delivers up to 400 cubic feet per minute (cfm) (680 m³/h), effectively circulating air in rooms up to 613 ft² (57 m²) and achieving three full air changes per hour.
Two-Stage Filtration: Equipped with a preliminary filter that captures most dust particles, protecting the main filter and extending its lifespan. The main filter features a unique TripleV design with a large surface area to reduce clogging.
Adjustable Settings: Offers two airflow levels—Eco mode for efficiency and Maximum mode for high air circulation—to adapt to varying dust levels.
User-Friendly Indicators: A signal light indicates filter status: green signifies proper function, while red alerts that the filter needs replacement.
Flexible Installation: Can be mounted from the ceiling (with an accessory) or integrated into dust protection walls. For larger spaces, multiple units can be operated simultaneously for greater coverage.
By effectively removing fine dust particles, the SYS-AIR not only improves air quality but also reduces the need for frequent cleaning, contributing to a healthier and more professional work environment.
