SPONSORED
Built with sealed ball bearings and no bushings, the Magnum MI-16210 dual sander features a 1/2 HP double-insulated direct-drive motor that creates less vibration and accommodates continuous-use applications. It’s compatible with 1″ and 2″ × 42″ belts and 8″ discs. An improved belt tracking mechanism provides controlled, accurate sanding while a quick-release belt tensioner makes changing belts easy. Both tables tilt and lock between 0° and 45° for accurate sanding on an angle. Whether you need to finish a wood project with some detailed sanding or sharpen tools or knives around the shop, the MI-16210 is up to the task.
