SPONSORED CONTENT
Get a Better Finish with a Helical Cutter Head Jointer
The King Canada 8″ Benchtop Jointer with Helical Cutterhead (KC-8HJC) features a cutter head with replaceable two-sided high-speed steel inserts.
If you work in a small shop where space is at a premium, you might want to consider purchasing a benchtop jointer rather than a stationary jointer. A benchtop jointer will deliver the same performance and precision as a stationary jointer. The King Canada 8″ Benchtop Jointer with Helical Cutterhead (KC-8HJC) features a cutter head with replaceable two-sided high-speed steel inserts. Simply loosen the holding screws and rotate the inserts to expose fresh cutting edges. The inserts are staggered so they provide a continuous cutting surface across the width of the cutter head delivering a better finish with less grain tear-out and fuzzing.
