SPONSORED CONTENT
King Canada 12″ jointer/planer with spiral cutterhead
If you work in a small shop, then you know how difficult it can be to arrange your machinery efficiently.
If you work in a small shop, then you know how difficult it can be to arrange your machinery efficiently. Adding new equipment can be next to impossible. Combination machines enable you to get more machinery per square footage of shop space than conventional stand-alone machines. Even if floor space isn’t at a premium in your shop, there are a lot of advantages to combo machines.
The King Canada 12″ Industrial Jointer/Planer (KC-12HJPC) features a 3HP 220-volt motor that runs more efficiently and cooler than a 110-volt motor. You’ll appreciate a more powerful motor when cutting thick, long stock. The spiral cutterhead is stacked with 5 rows of 12 high speed steel cutter inserts that deliver a smoother wood finish without grain tear-out and fuzzing even on the most highly figured woods. Installing (or rotating a fresh cutting edge) on a spiral cutterhead is a piece of cake in comparison to changing conventional straight jointer and planer knives.
A common misconception is that it takes a lot of time to switch from jointing to planing mode. On the King Canada KC-12HJPC change-over time to be under two minutes, so you spend less time fiddling around and more time creating.
Key Features:
- Precision cast-iron in-feed and out-feed tables
- Parallelogram table adjustment system keeps table close to cutterhead for improved finish and precise depth of cut adjustments
- Large 43″ x 6″ aluminum extruded fence pivots 0 – 45˚
- Magnetic safety switch
- Bridge-style cutterhead guard
