FB
ZenSharp sharpening system
The ZenSharp system is a solid, budget-friendly sharpening system for anyone who wants to get a sharp edge quickly and consistently, with minimal mess or skill.
Author: Carl Duguay
Diamond sharpening stones offer several key advantages. They cut very quickly because diamond is the hardest known abrasive, making them especially effective on tough steels like A2. One of their biggest benefits is that they stay perfectly flat over time, unlike waterstones, which tend to dish and require flattening. They also don’t need soaking or extensive maintenance — you can use them dry or with a little water, and they’re easy to clean. This makes them ideal for quick touch-ups or mobile sharpening kits. With proper care, high-quality diamond plates can last for many years, and they’re versatile enough to sharpen both steel and carbide cutting tools.
The ZenSharp sharpening system is a solid, budget-friendly sharpening system for anyone who wants a get sharp edge quickly and consistently, with minimal mess or skill.
Manufacturer: Zen-Wu Toolworks
ModelZenSharp sharpening system
Price: Pro Kit – $199 USD | Starter Kit – $115 USD
Warranty: Limited lifetime, 1 year worry-free return policy
Made in: China
SourceZen-Wu Toolworks
Starter Kit:
ZenSharp base
ZenSharp coarse, medium, and fine diamond cards
ZenSharp ultra-fine strop card (compound infused)
Wooden (maple) card holder
Household Magic Eraser (x2)
Pro Kit:
All items from the starter kit, plus
ZenSharp ultra-durable coarse and ultra-fine coarse cards
ZenSharp Kangaroo leather strop card (compound free)
Features:
  • Card size: 3″ by 8″
  • Grits: Rough- 45μm | Medium- 20μm | Fine- 9μm | Extra fine- 3μm
  • Material” diamond grit on steel base
  • Precision milled magnetic base
The new ZenSharp Sharpening System from Zen-Wu Toolworks offers a fresh approach to tool sharpening, combining industrial precision with the kind of speed and ease of use that both professional and hobbyist woodworkers will appreciate. Designed from the ground up to simplify the sharpening process without compromising accuracy or edge quality, it brings together a magnetic base, interchangeable diamond grit cards, and a range of options that make it equally at home in a busy workshop or a compact home woodworking space.
Core Design
At the heart of the system is a precision-milled base that serves as the foundation for all sharpening work. The base is engineered to maintain perfect flatness over time, supported by six robust legs. This stability is crucial, because it ensures that every pass of your chisel, plane iron or knife edge is perfectly supported and consistent. The base is magnetic, so the sharpening cards attach instantly and stay firmly in place during use, yet can be swapped out in seconds without any tools or fuss.
Sharpening Media
The sharpening media themselves are diamond grit cards, each engineered for a specific stage in the sharpening process. The system’s standard progression includes a coarse 45-micron card for rapid material removal and shaping, a medium 20-micron card for refining the edge, a fine 9-micron card for polishing, and an ultra-fine 3-micron strop card for bringing the edge to a mirror finish. Because these cards are based on diamond abrasives, they remain flat and cut aggressively for hundreds of sharpenings, far outlasting traditional waterstones.
Kit Options
Two main kit options are available.
The Starter Kit includes the magnetic base, the three diamond cards (coarse, medium, fine), the ultra-fine strop card that’s already infused with polishing compound, a maple card holder for organized storage, and two magic erasers for cleaning the cards after use.
The Pro Kit builds on this with additional specialized cards, including an ultra-durable coarse diamond card mounted on a steel substrate for heavy reshaping work, an extra ultra-fine diamond card, and a kangaroo leather strop card that comes compound-free for users who prefer to apply their own. The Pro Kit is clearly aimed at serious hand-tool users who want to keep multiple edges in top condition day after day.
Maintenance
Maintenance on the ZenSharp system is about as simple as sharpening gets. There’s no need for messy oil baths or soaking stones for hours. Instead, a quick mist of water or even a shot of ordinary glass cleaner such as Windex is all that’s needed to lubricate the surface before sharpening. Cleanup is just as quick — you can simply wipe the cards clean and, if needed, give them a light scrub with a Mr. Clean magic eraser.
There’s no need to flatten the surface as with waterstones, and because the cards are magnetic, replacing a worn card is as simple as lifting it off and dropping in a fresh one. This eliminates the time-consuming and often frustrating process of removing glued-down diamond sheets with heat guns and solvents.
Durability
One of the standout benefits of the ZenSharp system is its durability. Diamond cards don’t dish or hollow out the way waterstones do, and they maintain a flat, true surface even after extensive use. The industrial-grade diamond coating is the same type Zen-Wu uses in their own production facilities for sharpening chisels and plane irons before shipping them to customers, so the quality is proven in a professional environment. When the cards finally do wear down, replacements are available individually, which means you only need to replace the grits you use most often rather than buying a whole new set. For most hobbyist woodworkers, the cards should last for many years before needing to be replaces — if ever.
Practical benefits
The system’s compact size makes it ideal for small workshops, shared spaces, or even traveling toolkits. Everything is neatly contained, with the magnetic base taking up less bench space than most single waterstones. The card holder in the starter set keeps your grits organized and ready to go. Because swapping between grits takes only seconds, you can move quickly through the sharpening stages without breaking your workflow.
In day-to-day use, the magnetic base’s stability really shines. Unlike loose plates or stones that can shift during sharpening, the ZenSharp’s firm grip keeps the card exactly where you want it. This is especially important when working with narrow chisels or delicate knives, where any wobble can affect the edge geometry. This makes it easy to maintain a consistent bevel angle, whether you’re freehand sharpening or using a honing guide.
Cost effectiveness
The ZenSharp system is competitively priced with waterstone systems. The longevity of the diamond cards, the lack of flattening equipment, and the minimal maintenance requirements add up to significant savings over time. There’s also the convenience factor — being able to go from dull to razor sharp in just a few minutes without soaking stones or cleaning up slurry is a real advantage in a busy shop.
Final thoughts
The ZenSharp sharpening system is a modern take on an old-world process. It keeps the essentials — stable support, progressive abrasives, and consistent edge refinement — while removing the mess and inconvenience of traditional methods. Whether you sharpen daily or only when needed, it delivers a fast, clean, and reliable sharpening experience.
The ZenSharp Pro Kit
Precision-milled base with 6 robust anti-slip legs
Diamond cards magnetically attach to the base
xxxx
aaa
Published:
Last modified: September 4, 2025
Check out other tool articles
