FB
Top 10 most difficult things to do in a small shop
1. Building a Kitchen – A kitchen is so large that even when the cabinets are stacked on top of each other three high, there’s rarely enough room to take care of the trim and doors. I often have to store some of the cabinets in another spot for the last week or so of production.
2. Building a Wall Unit – Not as bad as a kitchen, but some wall units can include very tall cabinets, which pose a problem.
3. Keep the Noise Down – The planer and router are the worst, though my jointer and table saw also get used a fair bit. If it’s the middle of a weekday I tend not to do too much to keep the noise down, but early mornings, evenings and weekends I make sure to close the doors and windows when I’m making noise.
4. Keep the Neighbours Out – I get it; you like your neigh­bours, but this is the time you’ve carved out to be in the shop and you don’t want to chat it away. However, being friendly with all your neighbours makes them less likely to get angry at the noise you make.
.5 Lend a Tool to the Neighbour – Some neighbours are very respectful of tools, while others aren’t. Knowing how to tell the difference is important. It’s even worse when they don’t return a tool for months on end.
6. Get the Neighbour to Return the Tool – As I men­tioned, getting a neighbor to return a tool can be a challenge. I’ve considered making a sign-out list.
7. Keep the Shop Clean – Not my strength. A clean shop is nice to work in, but I’m sometimes too focused on production to worry much about it. It really only takes three minutes to sweep the floor. Having said this, I’m pretty good about keeping things organized and putting tools away.
8. Sharpen Tools – Chisels are the worst, but this is the case with lots of my hand tools. Sharpening is a time-consuming task, even if it creates tools that are a true joy to use. And I have a pretty good sharpening setup, so that’s not my excuse.
9. Maintain Tools and Machinery – When it really comes down to it, I will spend the time needed to maintain my collection, but since it means time away from being productive, I find it hard.
10. Leave on Time – For me, this one might be the hardest of them all. Even though I’ve been in my shop for hours, it’s often hard to leave on time. “Will you be home for dinner?” is the question I often get. The honest answer is “I hope so.” There’s always one more thing to do.
2 Comments
  1. I am a tradesman and do not loan my tools. I have no problem saying “NO”
    Many people do not know the same information as a tradesman. Example wood:
    new wood, old wood, wet wood, nails or screws embedded, knots, diseased wood, etc.
  2. Years ago, I once built a kitchen in a small shop. I used what I call the modular approach. First – you need to have very good drawings and measurements for what you will be making. I then made all the cabinet doors – machining enough rails and stiles first. I moved these to the shed to get them out of the way. I then jointed material and glued it up and planed it for all the cabinet door inserts. Once this was done, I built the cabinet doors one at a time storing the finished doors in the shed as I made them, then built the cabinets and drawers one at a time. At the time, I had a small overcrowded and dusty shop and this method let me get a relatively big job done.
More Top 10 Lists
Top 10 spray finishing techniques
Spray finishing can seem confusing, but with these...
Top 10 sanding tips
Sanding is the first step to obtaining a...
Top 10 router accessories
Although some of these accessories are shop-made, they’re...
