FB
A serious small shop for $10,000
Author: Ted Brown
Photos: Ted Brown
Published: June July 2012
Serious Small Shop
Serious Small Shop
Setting up a shop in your home is the only option for many amateur – and even some professional – woodworkers. There are lots of decisions to be made: electrical requirements, equipment selection, hand tool purchases, and shop layout are all crucial aspects of being successful.
[the_ad_group id="219"]
[the_ad_group id="206"]
My contention has always been that you can build a serviceable shop in your home, develop your hand skills, and make fine furniture. In the past year, I had an opportunity to build a shop from the ground up after moving to a new home. I found a house with an unfinished basement, and set to work. In this article, I will discuss everything from layout, to electrical, to equipment selection. I intend to name names with respect to equipment, so that readers will know what I chose. Everyone’s budget will be different, but I think almost everyone will be able to treat this as a starting point, and adjust accordingly, depending on their own budget.
Dead Space
Brown used the area under his stairway to store his dust collector. It was otherwise wasted space. Notice the iVACPro system to the left of the collector, simplifying dust collection.
Open for Business
When in use, the mitre saw station can handle pretty much anything thrown at it. The flip up surfaces will support a lot of weight.
Clean Air
This King air filtration unit removes fine wood dust from the air, and can be set to filter the air after you’ve left the shop.
Shop Workhorse
 Brown spends a lot of time working on his bandsaw. This General International 14" saw serves him very well.
Flat and Long
When selecting a jointer a 12" model would have been hard on the budget. He went with an 8" King model, and has been very impressed with it.
Great Value
 Another King product, this table saw is about half the price of comparable machines, and is well made. Just what Brown was looking for.
Big Savings
Rather than blow the budget on a full-sized planer, Brown opted for a DeWalt portable unit and saved thousands.
Easy Routing
 Durable and flat, this Jessem router table, fence and lift system offers a lot of nice features, and doesn’t break the bank.
Natural Light
 Brown positioned his bench near a window to get as much natural light as possible. His hand tool cabinets are adaptable, so when new purchases are made they find a new home next to his older tools.
Never Enough Clamps
Clamps are important no matter what type of work you’re doing. A good selection of “F”, “C”, spring and bar clamps will assist you for years to come, so make sure you like their comfort and feel.
Drill Press
Brown liked the features on this 15" Ridgid drill press. The sale price made purchasing it an easy decision.
Defining the space
My intent was to wall off about 2/3 of the basement footprint, to create an area that was well lit, had adequate electrical supply, and good dust collection to keep the dust from migrating to other parts of our home.
My shop ended up being 23 x 19 feet, for a total of 437 square feet. I put my wood rack in the basement, but out­side the walled in shop area. To keep the dust in the shop, a three part strategy was employed. I have a dust collection system, an air filtration system and a shop vacuum for cleaning dust out of machinery. I put up new walls, installed new electrical service, lighting, and two access doors for ease of materials move­ment. The shop includes two windows so that I can enjoy natural light, and not feel like I am squirreled away in the basement.
Layout
Shop layout is all about making the best use of space. Place your machines so that you have adequate “safe space” that you need to work around them. The “buffer area” beyond that is the amount of room you need to run large stock though a given machine, keeping in mind that buffer areas can overlap between machines. If you want to get more organized, buy some 1/4-inch squared paper, make scale models of each machine including the safe space around each, and place them on your model shop layout. Remember that buffer areas need to be long enough to put an 8′ sheet through a table saw, or a 6′ plank through your planer, for instance. I raised my planer, so that I can use the area above my router table to pass long planks through the planer – all it takes is some modelling, and a little shuffling, and you will find the layout that works for you. Each space will have chal­lenges; I had the area under the stairs that was wasted space, so I installed the dust collector there.
My bench is placed so I have access to it from all sides. It is nearest the window, to take advantage of the natural light.
Electrical
I wanted to have numerous outlets, and have enough elec­trical service that I did not have to worry about overloading circuits. There was already some lighting, so I simply picked off that line and added additional lights to keep things bright and cozy. I ran a 240V line for the table saw and jointer with a dedicated breaker. For wall outlets, I ran 14-3 wire, and split all the plugs, so that I can run one machine on the upper plug, and another on the lower plug of any outlet.
Perhaps the most satisfying move I made was to automate the dust collection system. I used the iVACPro system to link all machines to the dust collector. When I turn on any machine in the shop, the dust collector fires up and whisks the dust into the bin. The system also has a programmable delay to allow the dust to make it to the bin before the dust collector shuts down. I set my system for a five-second delay. The system works flawlessly for my band saw, planer, and router table at 115 volts, and also my table saw and jointer at 240 volts.
Out-feed and assembly table
You need an out-feed table to support work exiting the table saw and band saw. By placing the tools close together, I was able to make one out-feed table that works for both tools. I put four pivoting wheels on the table, allowing me to shift the table in any direction. By placing a shelf below the table, I gained some much needed storage space for portable power tools. Finally, since this is a large work surface, the table also serves as a true, flat assembly table.
Chop saw workstation
Cutting thick, rough, warped hardwood can be cumbersome and dangerous. To provide some control over this process, I built a chop-saw station with wings that extend to support long boards. Again, anytime you make something that consumes shop space, make a shelf underneath to gain storage. The chop saw sits in a recess so that the deck of the saw is at the same height as the workstation deck.
Controlling Dust
Make sure to run ground wires wrapped around all lengths of flexible exhaust hose to prevent static build up, which can spark and potentially ignite. I chose the King 1.5 HP dust collector, with a 115 volt motor, so I did not need special wir­ing for it. A shop vac is a must, as well, used to vacuum out machinery, and to remove dust from furniture prior to fin­ishing. Finally, an air filtration system was installed to clear the air of tiny airborne particles. The King KAC 650 unit I installed does a nice job, has a remote control, and a program­mable delay – I usually have the air cleaner run for a timed two hours when I leave the shop.
Machinery
Band Saw
I place the band saw first in my order of purchases, because I consider it the heart of the shop. Band saws are very safe tools for ripping, re-sawing, cutting curves and more because all of the force is downward, virtually eliminating any chance of unexpected kickbacks. I wanted a saw that had a strong back, dynamically balanced cast iron wheels for smooth operation and flywheel effect, 12″ depth of cut, good dust extraction design, a large table and a solid fence. After shopping around, I settled on the General International Model 90-170 14″ saw. It is very smooth, comes with an Excalibur fence, and it is light enough (133kg) to move into your basement without crushing someone.
Jointer
I could not consider a 12″ jointer, given that the equipment had to be moved down the stairs to my basement, and the cost would blow my budget. What I wanted in an 8″ jointer was true tables, a fence that is solid and easy to adjust, a cut depth gauge that is reliable, and long tables that aid in flat­tening longer bowed planks. I have found that the Taiwanese tools have come a long way in the past 20 years. I purchased the King KC-80FX 8-inch jointer, with lever adjust parallelo­gram tables. The system arrived in a good state of tune, and the well-written manual includes a full parts list and exploded parts diagrams. The tables were extremely heavy; more about getting things down the stairs later. The jointer is reasonably priced, it runs smoothly and it is well made.
Table Saw
I do not rip on the table saw as a rule, to prevent kick back that periodically occurs when natural wood pinches the blade, turning the wood into a missile. I bought a fairly powerful saw, so this is one place where a lighter saw would be adequate. Essentially, I use the table saw for ripping sheet goods, cutting dados, tenons, and cutting small parts to length – all of which can be done with a 1.5 HP saw. I ended up with a King 3 HP, three-belt drive, 10″ table saw. The castings are true, and the King Tru-rip fence reminds me of the Biesmeyer fence used on the Canadian General saws. The model is KC-11FX, and it can be purchased for less than half of the price of other, simi­lar saws. On this purchase, I went with the suggestion of Jeff at Brettwood Machinery – he was right; a very good value saw that runs smooth, and has a decent fence.
I added an accessory mitre gauge to the saw for accurate cut-off work. The Incra Miter1000 showed up under the Christmas tree after the Lee Valley flyer photo with part number mysteri­ously ended up on the fridge door with a circle around it last December. A great addition, the Incra is light, accurate, and provides adjustable stops for cutting multiple parts to precise length. I will also make a plywood cut-off sled for the saw for squaring larger panels.
Planer
This is the one tool in the shop that provides the greatest opportunity to save money, if you are willing to purchase a well made, light duty machine, and take lighter cuts. In the past I have used General 14″ planers that can hog off seri­ous cuts all day long. The problem is that these professional units cost over $5000, and they would crush my buddy as we haul them down the stairs (note: don’t be the guy on the bot­tom). After doing a fair amount of research, I purchased the Dewalt DW735 13″ thick­ness planer. The unit came with a good manual, and was in a good state of tune. It is light enough for me to carry around the shop with­out excessive grunting, so that made it very simple to install. The planer has a sig­nificant internal fan-assisted chip ejection system. The chips are catapulted out of this planer, so have your dust collector running before you run stock through it. I now have to make more cuts at a lighter cut depth, but I saved about $4500, which makes my budget happy. The planer makes clean cuts, and has two speeds. I don’t see a reason for the two speeds for my type of work, but there is a faster feed rate should you choose to use it. Knife changing is simple and quick.
I built a stand for the planer, raising the deck of the unit above the height of the router located next to it, allowing me to run long planks without interference. The stand is on wheels, with a shelf below.
Router Table
After years of digging down under router tables, lifting the entire unit up to change bits, and then fighting to get the plate flush again in the table, I chose to spend the money to pur­chase a router table, fence, and lift system. I did a thorough review of these systems, and chose the Canadian made Jessem Rout-R-Lift II kit. The system comes with a solid steel stand, a phenolic table, an adjustable extruded aluminum fence, and their base model lift system. For budget reasons, I did not choose the hefty Mast-R-Lift, but I am quite happy with the lighter Rout-R-Lift II. It will last me a couple of lifetimes, so it is the right system at the right price for me in my one-man shop. Hats off to Jessem for making a great lift at a very rea­sonable price in the middle of a tough economy. The table is durable, and flat. The direct drive lift is smooth and precise. I mated the lift system to a mid-sized model 690 Porter Cable router, which has a fixed speed, and enough power to do any­thing I need. The Jessem system uses a bayonet type mount for the table inserts, a nice touch that makes swapping the table insert quick and simple. As with all my machines, the router table is connected with the supplied dust port to my shop dust collection system with automated switching.
Drill Press
I looked around at many versions of Taiwanese drill presses. I ended up purchasing the Ridgid DP15501 15″ drill press because I liked the way the quill stop was made, the work light, key stor­age, and the easy access to the belt change system. This machine was also on sale when I needed it, so that made it a slam dunk. Choose the one that suits you, as they’re all very similar. The table is large enough, and the distance to the column is large enough to allow you to do most anything a small shop needs.
Hand Tool Cabinets
One of the challenges in building a cabinet for hand tools, is that as soon as you define a place for each tool in your custom cabinet, you find that you need more room to store the must have tools you just bought. I decided to make a couple of open cabinets, and employ the use of inserts that can be replaced or modified as my tool collection grows. Part of the goal was to make a clean, efficient shop, while keeping to a budget. I bought paint grade maple plywood and made the cabinets. Applying a solid maple face frame to the cabinet makes a clean looking cabinet from sheet goods purchased at $50/sheet.
Clamps
In my shop I use a large number of Jorgenson F-clamps. I use many of the small clamps, the most useful being the 12″ version. Large F-clamps are essential for cinching down parts on bending forms. I also like aluminum bar clamps because they are much lighter than steel clamps, and therefore less likely to damage a carcase should you bang into the wood dur­ing a glue-up.
Moving Machinery
One of the challenges we all face is how to move machines into a home without damaging the home, the machinery, or yourself. I actually had to bring things through the front door, and across hardwood floors, and turn 90° to descend the stairs into the shop. To protect the floors, I laid down sheets of 1/2″ MDF that I could use later. On the wooden stairs, I used three strips of softwood strap­ping, held with wood screws to the stairs. I mounted a 2×4 baton to the wall studs at the top of the stairs, with a 5/16-inch eye-bolt through it.
In each case, we shuffled the bench, jointer, table saw, and band saw across to the top of the stairs, and then tied a rope around each to act as a safety while sliding the machines down the strapping on the stairs. Yeah, the table saw hit the wall, and the promise of a good mud and paint job saved my bacon. The rope worked well, and we were able to get everything down the stairs nice and slowly with­out any major issues.
I set an initial budget of $10,000 to build the shop – everything from studs and drywall to hand tools and machinery. The final number was over by $1,000, but I’m still very happy with the result. The shop is now my haven, with a good sound sys­tem and good lighting. Every time I go back into the shop, it is exactly the way I left it, because it is my shop!
Ted Brown - tedbrown613@gmail.com
Ted is the owner of Blackwood Guitar Co. in Mallorytown, Ontario. where he makes custom guitars and teaches guitar making.
Other articles to explore
