SPONSORED
This self-centering clamp makes it super easy to square-up and clamp any picture frame from 5” x 7” through to 26” x 30” and anything in between. Made of durable aluminum and hard plastic components, the clamp applies balanced pressure on all 4 corners of the picture frame at the same time. Any hardened glues that drops on the clamp frame is easy to remove. A unique feature of the clamp pads are their double-ended design. When gluing, use the large end of the pad against the frame for easier positioning and clamp pad stability. If nailing the frame together, the smaller end of the pad allows for more access to the corner for nailing. $52.99
