SPONSORED
The DeWALT DCP580N is a cordless planer powered by a brushless motor, making it lightweight at 6.8 lbs. and easy to transport. It is a solid tool, but its biggest drawback is the HSS blades, which wear out quickly and require frequent sharpening. This is where Sheartak’s Spiral Cutterhead elevates the machine to a new level. DeWALT DCP580 Spiral Cutterhead.
Durability and Longer Lifespan
With 14 tungsten carbide inserts installed, the Sheartak cutterhead lasts 40 times longer than HSS blades. Each insert has four cutting edges, allowing you to rotate it for a fresh edge when one side dulls, eliminating the need for sharpening. The cutterhead is made from hard aluminum and include premium Japan-made bearings that can withstand heavy loads and cutting for long-term performance. Additionally, five extra inserts and screws are included, though you likely won’t need them for many years.
Superior Cutting Performance
The shear cutting action of the spiral cutterhead delivers cleaner, smoother cuts with a glossy finish. Unlike straight blades that chop into the wood, the angled inserts create a slicing motion that reduces tear-out and enhances the final surface quality. Whether you are cutting wood or shaping surfboards, you will notice the immediate difference in the quality of the cut, both visually and when you run your hand across the surface. One customer shared:
“The finish it leaves is far superior to the standard two cutter blades. My planer no longer clogs up, even cross-cutting.”
Quieter Operation and Less Vibration
Traditional HSS blades hit the wood all at once, creating loud noise and heavy vibration. The staggered cutting design of the Sheartak cutterhead reduces the contact surface and ensures that only a small section of the cutter engages with the material at a time. This minimizes the noise and vibration for a smoother and more pleasant operation.
Easy Installation
Worried about installation? It is straightforward, and we provide a step-by-step instruction video for your reference. A satisfied reviewer mentioned:
“Installation was straightforward with a couple of little blocks of timber… Very happy customer.”
Upgrade the DeWalt DCP580N with Sheartak’s Spiral Cutterhead for a tool that offers longer life, cleaner cuts, and a quieter, hassle-free operation.
If you have any questions or need assistance, don’t hesitate to contact us at sales@sheartak.com or call us at 1-519-880-8181.
