Category: 2025 Product Showcase
Monocoat Oil with Catalyst for Wood & Epoxy Surfaces
DUO by LIGNA is a catalyzed monocoat oil finish system...
Water-Repellent Hybrid Wood Oil for Exterior Surfaces
HYBRI-DECK by LIGNA is a hybrid water-repellent oil finish that...
Monocoat Wood Oil for High-Traffic Surfaces
EASY-SOLO by LIGNA is a monocoat oil fin­ish that colours,...
Water-Repellent Wood Oil for Exterior Surfaces
EXTERIA by LIGNA is a water-repellent oil finish that colours,...
Monocoat Wood Oil for Low-Traffic Surfaces
PRONTO by LIGNA is a monocoat oil fin­ish that colours,...
Solvent-Free Monocoat Wood Oil for Food Surfaces
BIO-SUPRA by LIGNA is a solvent-free mono­coat oil finish that...
KAPEX KSC 60: Precise Cuts and Power for the Entire Day
The Festool KAPEX KSC 60 Cordless Sliding Compound Mitre Saw...
CSC SYS 50: The Ultimate in Portable Precision
The Festool CSC SYS 50 Cordless Table Saw (#577378) is...
CXS 18 & TXS 18: The New Champions of 18 V Compact Drills
Light, compact and impressively powerful, the Festool CXS 18 (#576889)...
CXS 12: The Go-To Choice for Common Everyday Drilling and Driving Tasks
Light, compact and impressively powerful, the Festool CXS 12 Cordless...
TSV 60 KEB: The Perfectionist. Splinter-Free Cuts Like Never Before
Perfect from the very first cut. The Festool TSV 60...
TS 60 KEB: The Champion. The New Benchmark in Track Saws
Festool has been setting the standard for track saws for...
The reliable workhorse
The King Canada 8 Gallon Horizontal Air Compressor (8478) is...
Get a Superior Finish with a Helical Cutter Head Jointer
Enhance your woodworking with the King Canada 10″ Benchtop Jointer...
The ultimate cleaning solution for homeowners and DIYers
Effortlessly tackle tough cleaning tasks with the King Canada 3200...
Uninterrupted power during emergencies
The pinnacle of reliability, versatil­ity and innovation, the King Canada...
Portable power when you need it
The King Canada 3800W Gasoline/propane Inverter Generator (KCG-3800I-DF), with its...
Sharp tools give cleaner cuts
The King Canada 8″ Low Speed Bench Grinder (KC-895LS) is...
Sleek, convenient and versatile one-hand cutting
The Einhell 18V Cordless Compact One-Handed Reciprocating Saw (#4326318) is...
Versatile and powerful multi-purpose work light
The Einhell 18V 3600 Lumen Cordless Folding Panel LED Work...
Ideal for quick spills, spot cleaning and regular floor maintenance
The Einhell 18V Cordless Power Wet Mop (#3437120) offers a...
Convenient and efficient cleaning for shop or home
The Einhell 18V Cordless Deluxe Handheld/Stick Vacuum (#2347195) is a...
Versatility and power for all your drilling and driving tasks
The Einhell Cordless 1/2″ Drill/Driver & 1/4″ Impact Kit (#4257245)...
Optimum power to loosen and tighten the toughest nuts and bolts
The Einhell PROFESSIONAL Cordless Impact Wrench & Driver (#4510071) is...
The Ultimate Precision Joinery Machine
The PantoRouter woodwork­ing machine makes joinery fast, accurate, safe, repeatable...
Flexcut Pro Range 3-Pack (Full Sized Handle)
The Flexcut Pro Range 3-Pack (#FP200) offers a trio of...
Flexcut Precision Detail 2-Pack (Small/Slim Handles)
The Flexcut Precision Detail 2-Pack (#FP100) is perfect for carvers...
Flexcut 1-3/8” Pro Detail Knife
The Flexcut Pro Detail Knife (#FP01) is a masterfully crafted...
Magnum Industrial 2″ × 42″ Belt and 8″ Disc Sander
Built with sealed ball bearings and no bushings, the Magnum...
Magnum Industrial 1 HP Bag Dust Collector
A mobile dust collector with an easy-to-clean 2 micron filter...
Magnum Industrial 14″ Wood Bandsaw
The Magnum MI-91340 bandsaw is a real work­horse with a...
Magnum Industrial 14″ Benchtop Drill Press
The Magnum MI-76100 is a rugged, powerful and accurate drill...
Magnum Industrial 6″ Straight Blade Benchtop Jointer
The compact Magnum MI-81100 jointer is ideal for small shops...
Magnum Industrial 13″ Helical Head Planer
With a precise helical cutter head equipped with 26 long-lasting...
