Category: 2024 Small Shop Essentials
Monocoat Oil with Catalyst for Wood & Epoxy Surfaces
DUO by LIGNA is a catalyzed monocoat oil finish system...
Water-Repellent Hybrid Wood Oil for Exterior Surfaces
HYBRI-DECK by LIGNA is a hybrid water-repellent oil finish that...
Monocoat Wood Oil for High Traffic Surfaces
EASY-SOLO by LIGNA is a monocoat oil finish that colours,...
Water-Repellent Wood Oil for Exterior Surfaces
EXTERIA by LIGNA is a water-repellent oil finish that colours,...
Monocoat Wood Oil for Low-Traffic Surfaces
PRONTO by LIGNA is a monocoat oil finish that colours,...
Solvent-Free Monocoat Wood Oil for Food Surfaces
BIO-SUPRA by LIGNA is a solvent-free monocoat oil finish that...
Magnum Industrial 2” × 42” Belt and 8” Disc Sander
Built with sealed ball bearings and no bushings, the Magnum...
Magnum Industrial 1 HP Bag Dust Collector
A mobile dust collector with an easy-to-clean 2 micron filter...
Magnum Industrial 14” Wood Bandsaw
The Magnum MI-91340 bandsaw is a real workhorse with a...
Magnum Industrial 14” Benchtop Drill Press
The Magnum MI-76100 is a rugged, powerful and accurate drill...
Magnum Industrial 6” Straight Blade Benchtop Jointer
The compact Magnum MI-81100 jointer is ideal for small shops...
Magnum Industrial 13” Helical Head Planer
With a precise helical cutter head equipped with 26 long-lasting...
The Perfect Tool for Tires, Air Mattresses and Small Inflatables
Nothing beats the Einhell 18V cordless high pressure inflator (#2071020)...
The Lawn Tamer
Whip your lawn into shape with the Einhell 21″ self-propelled...
Apply Finishes Like a Pro
The easiest way to apply finishes to cabinets, furniture, walls...
The Quick and Easy Way to Clean Shop and Home
With the Einhell 18V cordless stick vacuum (#2347184) you can...
Tiny But Mighty Pruning Chainsaw
At just under 2-1/2 pounds the Einhell 18V cordless pruning...
Retractable Mount-Anywhere Cordless Water Hose Reel
The Einhell 18V cordless water hose reel (#4173779) delivers outstanding...
The Ultimate Precision Joinery Machine
The PantoRouter woodworking machine makes joinery fast, accurate, safe, repeatable...
Durable and Versatile Paste Wax Finish
Walrus Oil Furniture Butter is an oil- and wax-based finish...
CSC SYS 50: The Ultimate in Portable Precision
The Festool CSC SYS 50 Cordless Table Saw (#577378) is...
KAPEX KSC 60: Precise Cuts and Power for the Entire Day
The Festool KAPEX KSC 60 Cordless Sliding Compound Mitre Saw...
CXS 18 & TXS 18: The New Champions of 18 V Compact Drills
Light, compact and impressively powerful, the Festool CXS 18 (#576889)...
CXS 12: The Go-To Choice for Common Everyday Drilling and Driving Tasks
Light, compact and impressively powerful, the Festool CXS 12 Cordless...
TSV 60 KEB: The Perfectionist. Splinter-Free Cuts Like Never Before
The Festool TSV 60 KEB Plunge-Cut Saw (#576735) with scoring...
TS 60 KEB: The Champion. The new Benchmark in Track Saws
Festool has been setting the standard for track saws for...
Ultimax Ligno – The Ultimate Abrasive for Wood Sanding
The new Mirka Ultimax Ligno abrasive is tailored for hard...
The Best Way to Control Dust While Sanding
If you want a cleaner, healthier workshop, you need to...
The Ultimate Sharpening System
The new M.POWER SB2 Four Stage Sharpening System offers instant...
Roarockit Manual Vacuum Press
The Thin Air Press Kit is a simple, efficient and...
More work, less pain
Kneel-It is a cleverly engineered support device designed to relieve...
Drill Precisely Positioned Straight or Angled Holes
The King Canada 15″ Variable Speed Drill Press (KC-15HS-VS) provides...
This Cabinet Saw Delivers Power, Stability and Accuracy
The King Canada Left-Tilting 10″ Table Saw (KC-10KX/U30) gives you...
Compact and Affordable Bandsaw
The King Canada 12’’ Bandsaw (KC-1202FX) features a powerful 3/4...
Versatile and Powerful Belt and Disc Sanding
The King Canada 6″ by 48″ Belt and 9″ Disc...
Get a Better Finish with a Helical Cutter Head Jointer
The King Canada 8″ Benchtop Jointer with Helical Cutterhead (KC-8HJC)...
Great Value in a Compressor That’s Built to Last
The King Canada 8 Gallon Horizontal Air Compressor (8478) features...
Fuji Spray Q5 PLATINUM HVLP system
The Q5 Platinum turbine with its powerful five-stage motor develops...
Vertical ratcheting clamps for MFT-style worktables
Ratcheting Lever (KLI20-MFT-SET) combines quality and functionality for fast, easy...
Horizontal cam-action clamps for MFT-style worktables
Secure your workpieces for precision routing, sanding, drilling and cutting...
