Category: 2024 Hot Products
Melbourne Tool Company Block Plane
The Melbourne Low Angle Block Plane (MTC-49407) features a 12°...
Horizontal Cam-Action Clamps for MFT-Style Worktables
Secure your workpieces for precision routing, sanding, drilling and cutting...
Vertical Ratcheting Clamps for MFT-Style Worktables
Based on the popular KliKlamp style, the new Bessey Table...
Effortless Pruning Promotes Green Growth
The 18V Einhell Cordless Pruning Shears (#3408304) help alleviate strain...
Shred and Compost Leaves Effortlessly
The 18V Einhell 3-in-1 300 CFM Cordless Leaf Blower/Vacuum/Mulcher (#3433647)...
Low Weight – High Convenience
The compact, brushless 18V Einhell 395 CFM Leaf Blower (#3433556)...
The Perfect Small Chainsaw for Occasional Use
At just nine pounds, the Einhell 12-inch 18-volt cordless...
Tame Your Garden with Cordless 28″ Hedge Trimmer
Designed for both professional landscapers and DIY enthusiasts, this 36V...
Trim Overhead Branches and Shrubs Quickly and Safely
Cut branches and trim high hedges easily and safely from...
Keep Your Cutting Tools in Tip-Top Condition
With the King Canada 6" Bench Grinder (#KC-690LN), you can...
Never Lose Power Again
The King Canada Power Force 10,000W Tri-Fuel Generator (#KCG-10002GE-TF) with...
Air When You Need It
Equipped with a powerful 7.5 HP motor and magnetic starter,...
Get Smoother Wood Surface Finishes and Reduced Tear-out
Equipped with 26 two-sided cutter inserts, the King Canada 13''...
Designed for Precision and Intricate Cutting
Equipped with a 1.3 amp DC motor that delivers variable...
Great Combination of Performance, Precision, Portability and Price
The King Canada 6" Benchtop Jointer with Helical Cutter Head...
Monocoat Oil with Catalyst for Wood & Epoxy Surfaces
DUO by LIGNA is a catalyzed monocoat oil finish system...
Water-Repellent Hybrid Wood Oil for Exterior Surfaces
HYBRI-DECK by LIGNA is a hybrid water-repellent oil finish that...
Monocoat Wood Oil for High-Traffic Surfaces
EASY-SOLO by LIGNA is a monocoat oil finish that colours,...
Water-Repellent Wood Oil for Exterior Surfaces
EXTERIA by LIGNA is a water-repellent oil finish that colours,...
Monocoat Wood Oil for Low-Traffic Surfaces
PRONTO by LIGNA is a monocoat oil finish that colours,...
Solvent-Free Monocoat Wood Oil for Food Surfaces
BIO-SUPRA by LIGNA is a solvent-free monocoat oil finish that...
The Ultimate Precision Joinery Machine
The PantoRouter woodworking machine makes joinery fast, accurate, safe, repeatable...
Mirka DEROS – The Compact and Easy-to-Use Sander
Low vibration, quiet running, a comfortable grip, minimal heat-up and...
Ultimax Ligno – Simply the Best Abrasive for Sanding
The new Mirka Ultimax Ligno abrasive combines a fast cut...
CSC SYS 50: The Ultimate in Portable Precision
The Festool CSC SYS 50 Cordless Table Saw (#577378) is...
KAPEX KSC 60: Precise Cuts and Power for the Entire Day
The Festool KAPEX KSC 60 Cordless Sliding Compound Mitre Saw...
CXS 18 & TXS 18: The New Champions of 18 V Compact Drills
Light, compact and impressively powerful, the Festool CXS 18 (#576889) and...
CXS 12: The Go-To Choice for Common Everyday Drilling and Driving Tasks
Light, compact and impressively powerful, the Festool CXS 12 Cordless Drill (#576869)...
TSV 60 KEB: The Perfectionist. Splinter-Free Cuts Like Never Before
The Festool TSV 60 KEB Plunge-Cut Saw (#576735) with scoring...
TS 60 KEB: The Champion. The New Benchmark in Track Saws
Festool has been setting the standard for track saws for...
Magnum Industrial 2″ × 42″ Belt and 8″ Disc Sander
Built with sealed ball bearings and no bushings, the Magnum...
Magnum Industrial 1 HP Bag Dust Collector
A mobile dust collector with an easy-to-clean 2 micron filter...
Magnum Industrial 14″ Wood Bandsaw
The Magnum MI-91340 bandsaw is a real workhorse with a...
Magnum Industrial 14″ Benchtop Drill Press
The Magnum MI-76100 is a rugged, powerful and accurate drill...
Magnum Industrial 6″ Straight Blade Benchtop Jointer
The compact Magnum MI-81100 jointer is ideal for small shops...
Magnum Industrial 13″ Helical Head Planer
With a precise helical cutter head equipped with 26 long-lasting...
