Upholster a Simple Cushion
Author: Rob Brown
Published: October November 2017
With only a few items from a fabric store, and no experience, you can make a simple, customized upholstered cushion for a piece of furniture.
  • DIFFICULTY
    1/5
  • LENGTH/TIME
    1/5
  • COST
    3/5
Upholstery is a whole different ballgame than woodworking. But because this specific upholstery task didn’t seem too hard, I figured even though I had no experience at all I could probably get a decent result without too much work. Turned out I was right. The finished cushion works well, looks good, and it took me well under an hour to compete.
Ease the Edge
A trim router, equipped with a small roundover bit will make quick work of any sharp edges on the plywood base.
Trim the Rubber Foam
Use a sharp knife or plane blade to trim the foam to the same dimensions as the plywood base.
Measure for the Batting
Measure from the one underside of the plywood to opposite side, then add an extra inch so the batting can slightly wrap underneath the plywood base.
Tack the Fabric in Place
A couple of staples in each side will position the parts of the cushion in place (left), before adding more staples across all four sides to secure the fabric for good (right). Don’t staple within about 1" of the corners for now. Use a hammer to fully seat the staples as you work, and be sure to use staples that will not protrude through the plywood base.
Tighten the Corners
Brown pulled the fabric over each corner and stapled it in place.
Even the Corners Out
Being careful to leave a nice visual transition at the outer edge of each corner, Brown folds the fabric, pulls it taut, then staples it in place.
Remove Excess Fabric
For the cushion to sit nicely on the table, some of the fabric might have to be removed. Just be careful not to remove too much, as you can weaken the corner area, causing the fabric to fray or come undone.
Finish it Off
Fold the other half of the fabric over, check the pleat on the outer edge of the cushion, then staple the section down.
Visit the fabric store
I selected a piece of 2″-thick rubber foam, which was more expensive than the other options but was the perfect density for this project. I added a few layers of polyester craft batting over top of the rubber foam. This was sold in a larger size and is fairly thin, so I was able to fold it into three layers for my cushion. These layers provide a more even look and shape to the finished cushion.
Next was the fabric. The hard part was selecting the colour and pattern. Let the people assisting you at the fabric store know what you’re using the fabric for, and they’ll be able to help you choose an appropriate fabric for the project. Make sure to choose something that won’t fray easily when you wrap it around, and staple it to, the plywood base. In hindsight, I used a fabric that was a bit too stretchy, and I had to add a lot of staples. I would opt for a thicker fabric next time. All told, I managed to keep the price tag for fabric, rubber foam and batting under $100.
Start with the plywood base
Cut a piece of 3/4″-thick plywood to the width and length you want the cushion to be. I left 1/2″ between the edges of the cushion and the edges of the table. Next, slightly ease all the edges of the plywood base. I opted for a 1/8″-diameter roundover bit in my trim router, but sanding the edges heavily would also work.
Lay the plywood base on top of the rubber foam and cut the foam to the exact same size as the base. I used a plane blade, as it was sharp and could cut deep enough. Next comes the batting. Lay the rubber foam over the plywood base, and measure from the underside of one side of the base to the bottom of the other side, then add about 1″ to that dimension. Repeat for the other direction, then cut the batting those sizes. I removed a 2″ × 2″ square from all four corners of the batting, in order for it to more evenly wrap around the corners.
Add the fabric
Cut the fabric to size next. You want it to cover the upper surface of the cushion, wrap down all four sides, and extend at least 3″ under the plywood base. Because I was afraid I would cut the fabric too small, and ruin it, I left a few extra inches on each of the four sides.
Place the fabric face down on a flat, clean surface, then add the batting, rubber foam and plywood base on top, centered over the fabric. Pull one edge of the fabric up and over an edge of the plywood and tack it in place with a few staples. Unless your fabric is really stretchy, you likely don’t have to pull it as taut as you’d think. Repeat for the other three sides, then carefully check if the fabric is tight enough. If either too tight or not tight enough, you can remove the staples and start over.
With the four sides started you can then add a few more staples around each of the four sides, working around the base and pulling the fabric evenly. Don’t staple the fabric too close to the corners.
Dealing with the corners
There are a few ways to approach the corners, but as long as you finish with even, tidy, taut corners I don’t think there’s a wrong way. First I pulled the fabric that was centered over the corner taut, and stapled it in place. Then I adjusted the fabric between the corner and the straight sections so it was snug, and there was an even pleat on the edge of the cushion, and stapled the fabric in place, before repeating on the other side of this corner. There was a bit too much fabric near the underside of the corner, so I used scissors to remove a bit; just don’t remove too much, or there won’t be enough fabric to be properly secure the corners. Repeat with the other three corners, and you’re done. Use a hammer to ensure the staples are driven into the plywood base fully.
The underside of my cushion didn’t look professionally done, to be quite honest, but since it was going to be fixed to the table nobody would ever know. I’m happy with the finished look, but I’ve already caught myself thinking of what fabric I’ll use when I reupholster the cushion in a few years. At that point I’ll likely be able to reuse the foam and batting, so new material with be my only cost.
Rob Brown - [email protected]
