FB
Trees hit hard in ice storm
Blog by Rob Brown
Typical View
Last weekend, an ice storm hit our area. In fact, it stretched across a large portion of Ontario, dropping between 20 and 30 mm of ice onto roads, sidewalks, vehicles, fields and buildings.
I can’t speak to the other areas where the storm hit, but the roads and sidewalks in Peterborough were salted and sanded before the storm, so they were surprisingly clear of ice. It took me a while to scrape my car free, but it was far from awful.
The poor trees
The trees fared the worst of all, though. Between the huge number of smaller branches, large limbs and entire trees that were brought down to the ground, just about every tree nearby was damaged in some sort of way. And there’s a domino effect; when trees and branches come down, they often damage power lines. There was also enough ice on the power lines to make the situation even worse.
We don’t usually think of trees having a critical role in how our towns and cities work, other than providing oxygen and shade during the warm months. Although they give us so much, there can be a potentially serious downside to trees. Not only can they bring down power lines, but they can also damage homes, vehicles and even people as they fall.
I’m not for a second implying we should cut down all the trees or stop planting them in our towns and cities. I’m just saying we should be aware of their size and weight and treat them with full respect.
Pitch in
Our power was out for about two days, but thankfully it’s back on now. Many of our neighbours are still out of power, with no idea when it might come back. We’ve had an extension cord running from our place to our neighbours’, so they can at least have a bit of electricity to keep their fridge cold, turn a light on, recharge their phones and make a hot beverage.
We got out with my kids to help clear a few neighbours’ fallen trees. We also went to a few local trails and paths to see about removing some of the fallen trees so folks could pass through the area. It was actually surprisingly satisfying, not only to help out the community, but to use a chainsaw, a pair of loppers and a few handsaws to cut up and move the wood. It was good, honest work where you get your hands dirty and feel great from the exercise.
One benefit to fallen trees
As I was cutting up the neighbours’ flowering cherry tree, I couldn’t help but notice the colours of the sapwood and heartwood. The two colours –one deep reddish brown and the other a pale yellowish white – contrasted beautifully. I thought to myself, “This would make some great spoons,” so I took a few pieces home.
School’s out
Over the next few days schools were closed. Both my kids were fine with that, but I hate seeing kids sit idle. Once the power came back on, we were able to split up one of the chunks of cherry and each try our hands at making a spreading knife. After I worked the wood into smaller pieces, they used a scroll saw to rough out the shape. We all then set to work with our knives. Over about an hour we all worked side-by-side, obeying safety rules to keep our fingers safe and grain rules to make the work easier. Carving by hand definitely makes you realize how the grain direction affects chip formation. Both kids seemed to catch on pretty quickly.
Working with green wood was really enjoyable. While kiln-dried wood is hard and brittle, wet wood is soft and forgiving. It even changed colours as we worked; the heartwood turned from a deep reddish brown to a lighter reddish brown within about 30 seconds of exposing fresh wood with our sharp knives.
Right now, the knives are drying out. We will make the final shaping cuts in about a week, when the wood is much dryer, then apply a finish to the knives. I was considering giving my knife to our neighbors who lost the tree, as they really loved it. From the colourful spring blossoms to its attractive overall shape, the tree will be missed.
We’re lucky
While we’re enjoying having our power back and making knives, many around us are still living in the cold and dark a power outage creates. Thankfully it’s not too cold this time of year, but the warming freezers and lack of hot water only add to the other challenges of life. Some of the trees that were bent right over until their tops touched the ground, are now mostly straight. Like everything, there are pros and cons to trees. The tree giveth and the tree taketh away.
Typical View
A few doors down from us is a group of trees that was hit pretty hard.
Typical View
About One Inch
This view shows how much freezing rain fell during the storm. About 1" of ice is covering the thin branches of this tree.
About One Inch
Power Lines
As if the trees falling on them wasn’t enough, virtually every single power line in Peterborough was covered with a heavy layer of solid ice.
Power Lines
Fencing
Here, ice covers a chain link fence.
Fencing
Flexible Trees
Our little serviceberry tree, which was just planted last year, got bent over until its top was touching the ground. Thankfully, once it warmed up, the tree straightened out again.
Flexible Trees
Making Use of the Wood
My kids and I got into the shop to make something from the dead trees.
Watch Your Grip
I reviewed a few of the basic knife grips before we started and the kids each did a great job creating a knife.
Watch Your Grip
Our Results
Our three knives, which are now all drying and waiting for the final few cuts to be made on them.
Our Results
Widespread Damage
This is on the Trans Canada Trail, a few minutes from our home. The derecho that swept through this area a few years ago caused a huge amount of damage, taking out all the weaker trees and branches, so it was a surprise to see how much damage was caused by the recent ice storm.
Lots of Weight
A closeup look at one tree in the area, laden with ice.
Published:
Last modified: April 3, 2025
Rob Brown - [email protected]
5 Comments
  1. Advertisement
  2. We live halfway between Barrie and Orillia. The power went off about 10 am Saturday March 29 and just came back on this morning (April 8). I hope the woodworkers who had power early on haven’t scouraged all the good wood around here! I had not thought of this, mainly because I have been busy with other issues, but I am heading out tomorrow.
  3. Rob, I live south east of you and have lost lots of trees and branches. As sick as it feels and starting the process of clean up, I like the idea of finding wood that will be fun to use in the shop. I need to take more care before the cut up to look for that “diamond in the rough.”
  4. My daughter lives in the Orillia area and have been using there back up power since 2:00 am last Friday. From the few photos she has been able to send, the trees have suffered really badly, 10-12 inch branches broken off.
